How strong is 89 10bolt
Old Sep 9, 2003 | 09:41 PM
stone89ROC's Avatar
Car: for now my Jeep while im building my Camaro
Engine: building a 350 with about 440HP and 450lb
Transmission: W.C. T-5 dont know how it will hold up..
i have a 89 IROC and im putting in a 357 that has 400ftlb and 440 HP. and some radial tires. the guys at the machine shop said i would be fine that all i would do under alot of tourge is brake traction and therefore not putting stress on my rear end. they said i would brake my rear only if i put some drag tires on it and caught traction but will my rear end still hold up with radials on it ??
Old Sep 10, 2003 | 05:38 AM
ede's Avatar
ede
same rear is in 4th gens with the ls1, runs low 13s from the factory. lot depends on how you apply the power to the ground. a girddle and welding the axle tubes will add a lot of strength.
Old Sep 10, 2003 | 09:52 AM
bigals87z28's Avatar
Car: Check The Sig
10 bolts are really weak, and instead of buying new gears, new posi, and axles every time you go to the track, 1500-2k for a 12 bolt would be a good idea. It will take a lot of power to destroy a 12 bolt. Just a thought. Your gunna put on DR's or slicks at some point to get traction cause you will spin.
Old Sep 10, 2003 | 02:54 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
10 bolts are junk, u can kill them behind a stock engined car. been there already. if u really wanna bullet proof the rearend get a ford 9" setup. lighter hten the 12 bolt and stronger too i think. even richmond the gear company says 350hp is over the limit for a 10 bolt even with a girdle etc.
RS Reaper
Oct 17, 2018 07:52 PM
69GTOby
Apr 18, 2016 02:34 PM
BLK87Z
Sep 18, 2015 11:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Glowsock
Sep 11, 2015 11:09 PM
