T56 is in! quick question about speedo
Old Sep 10, 2003 | 08:04 PM
Fbody fan 35yrs's Avatar
Car: 91 Z/28
Engine: 5.0
Transmission: T-56 6 speed
After being on the back burner for a while, my auto- to- T56 swap is almost done!!! The car drives fine and the ebay gods treated me well with a sound tranny. I ordered the conversion box for the speedo tonite. I expected the ecm to throw a code with out the speedo wire hooked up and it didn't let me down. As soon as the code hit I lost my idle, which is what I expected. The question...... after I install the conversion box, and reset the ecm will the problem resolve it self with out me doing anything else? What about the lock up wire?, will I need to do anything with it? I had the chip reprogrammed to Manual trans, and turned off some of the stuff I wouldn't need (speed limiter) and a few others. Any thoughts on this would make an old hot-rodder happy! Thanks!
Old Sep 10, 2003 | 11:52 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Re: T56 is in! quick question about speedo
In order (assuming you get the signal converter installed correctly): Yes, tie it up and leave it alone, no.
HTH
Old Sep 11, 2003 | 07:41 AM
Car: 91 Z/28
Engine: 5.0
Thanks Matt!! On that note, if there is any experiences with hooking up the "box"................ wrong or right. I have a 3.73 gear.
Jorlain
Aug 24, 2022 05:11 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
