help w/ 5 speed in my S10
Old Sep 15, 2003 | 06:35 PM
RiceKiller87's Avatar
Car: '87 IROC
Transmission: 700-R4
i have a 94 S10 w/ a 4.3L and 5 speed. when i shift gears,my trans. makes noise....not grinding,its just like u can hear it being shifted and i dont think its supposed to be like that. And another thing is that if i try to put it into reverse,it grinds....but if i put it in like 1st or 5th and then do it,its fine...WTF??
i checked the clutch fluid and it appeared fine.
thanx for any help
Old Sep 17, 2003 | 01:00 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
well its probably your clutch master cylinder.normaly the slave cylinder leaks when its bad. dont by a cheap c/m. i did 2 months ago and it solved the problem, but now its leaking down already so im gonna have to go and do it again.
Old Sep 17, 2003 | 01:49 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Re: help w/ 5 speed in my S10
thanx for any help
Well you got yourself a run of the mill 5 speed thats had a replacment clutch. They all do that, if you replace the slave it might help but get one from GM or nappa pre-bled ready to rock & roll or you will never get the air out. For some reason the replacment clutch set's are a nats **** smaller and the tad bit of air trapped in the slave wont let it push as much as they should.
Old Sep 17, 2003 | 01:59 PM
Car: 91 RS
Engine: LO3
i think you just explained every thing thats wrong with my tranny. thanx!
Elephantismo
Feb 13, 2019 12:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
buckshot63
Sep 10, 2015 09:15 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
