9 bolt discs to gm 10 bolt
Old Sep 16, 2003 | 04:59 PM
little2crazy25's Avatar
Car: 1987 Z-28
Engine: 406
Transmission: th 400
curious if the disc setup on a nine bolt will fit a gm 10 bolt. i have a 9 bolt with 2:77 and i want to go to 4:10 so i am going to use my ten bolt but was wondering if the disc brake setup will fit on my ten bolt so i can replace the drums
Old Sep 16, 2003 | 10:38 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
With that combo, you'd be better off staying with the 9 bolt and upgrade the gears.
Miles
Old Sep 17, 2003 | 03:42 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
9bolt.com will have spacers to use lower gears on the 2:77 carrier. Cheaper then getting a series 3 carrier and gears.
Old Sep 18, 2003 | 08:38 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the 10 bolt rears and the 9bolt rears have differant flange pattern for the backing plates. (to answer your question!)
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
84 TA NV
Sep 6, 2015 08:02 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
