Aluminum Driveshaft?
Old Sep 17, 2003 | 08:49 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Do aluminum driveshafts help that much? What I was thinking is they either give you more of an RPM range or they transfer more HP and torque over to rear wheels, but I'm not sure.
Old Sep 17, 2003 | 08:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They reduce the total rotating mass that has to be accelerated from 0 RPM to whatever their RPM is at the finish line. It's not a real big thing, but every little bit helps.
Old Sep 20, 2003 | 11:16 PM
onebinky's Avatar
When my dad had his 92, he swapped to aluminum. It made a very small difference in acceleration. Like RB83L69 said, it's just less weight for the engine to turn.
Matt
Old Sep 20, 2003 | 11:57 PM
kevin arnold's Avatar
Car: 1987 ta
Engine: 355
Transmission: t 5
dumb question... did formulas come with aluminum drive shafts. thanks
Old Sep 23, 2003 | 10:59 PM
Car: 1987 ta
Engine: 355
Transmission: t 5
just checked faq page sorry and thanks
Old Sep 23, 2003 | 11:22 PM
Car: 1987 ta
Engine: 355
Transmission: t 5
Old Sep 24, 2003 | 02:20 PM
kahamri's Avatar
Car: Camaro
Engine: More than one
Transmission: More than one
They do make a pretty decent change...Nothing like nitous though.. It's less weight, so it's quicker to get up to speed, because it's easier for your engine to turn, also it is alot less strain on your tranny and engine cause it's lighter and eaiser to move..think aobut yourself..you wana turn somthing heavy for hours on a day, or would your rather it be light? Had a aluminum on on the 2002 ss...it twisted..had to get the steal one back on...Carbon fiber is just too expensive..
Old Oct 9, 2003 | 09:06 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
aluminum shaft
this is a easy swap sves all of 5 lbs the neat thing is a 4th gen will bolt right in i have a 98 in my 87 ta so any ls1 alum shaft will fit std or auto look on ebay 125-175$
:lala:
Old Oct 10, 2003 | 03:18 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i just got a practically brand new one of ebay for 146 shipped, not abd at all, deosnt even look used. i beleive they are 10 lbs lighter then the steel AND they are a lot safer due to not having a critical speed like a steel shaft does. this means when ur doin 140 the saft isnt likely to vibrate so bad it comes through the floor pan on ya.
Old Oct 10, 2003 | 06:56 AM
zman1969's Avatar
Car: 90 Formula 350
alum shaft
no theyre only 5 lbs lighter i weighed them
:lala:
Old Oct 10, 2003 | 09:40 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
which one did you weight?
the LS1 shaft is lighter than the 1le shaft.
Old Oct 10, 2003 | 05:48 PM
zman1969's Avatar
Car: 90 Formula 350
i weighed the stock steel one out of my 87 vs. a ls1 98 and there was 5 lb difference
how much difference between the 1 le and the ls 1?
Old Oct 10, 2003 | 05:54 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i cant prove it, but i think theres more then one alum 4thgen driveshaft.
Old Oct 10, 2003 | 06:06 PM
zman1969's Avatar
Car: 90 Formula 350
why would they bother? these are just production cars
Old Oct 10, 2003 | 06:21 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
The 1LE was just a production car too.
Old Oct 10, 2003 | 06:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i look at alot of the changes made to production cars and go..... WTF?! why the heck would they change that!?
theres a million possible reasons besides whats best for the car... could be cutting costs, or they subcontracted a diff manafactuer, who knows..?
im just getting the impression that there is more then one.
Old Oct 11, 2003 | 01:48 AM
25THRSS's Avatar
The third gen 1LE driveshaft is lighter than the LS1 shaft. The third gen shaft is smaller in diameter than the LS1 shaft.
Old Oct 11, 2003 | 06:27 AM
zman1969's Avatar
Car: 90 Formula 350
that dosent necesarily mean its lighter... have you weighed them?
it may be of thicker material for strength
as actual diameter affects overall strength
Linson
Oct 24, 2025 02:00 PM
loud91rs
Oct 5, 2015 10:05 PM
