What's the difference between a camaro and mustang t-5?
Old Sep 23, 2003 | 03:17 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Actually it's a question for a co-worker. What's the difference between a mustang and a camaro t-5. Other than the obvious bellhousing. What are the similairities and differences in the box itself and gear ratios.
Old Sep 23, 2003 | 03:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Very little, other than things that fit them to their respective cars.
The main parts of everything are the same; same diameter shafts & gears, etc. The Mustang gear ratios tend to be wider than the GM ones. A V8 Mustang trans has about the same ratios as a 6-cyl GM one.
The splines on the clutch gear and the mainshaft are different.
Frozer!!!
Jan 19, 2024 04:55 PM
onefreakz
May 14, 2018 12:15 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
antares57
Aug 6, 2015 07:47 AM
