Vibration Until I push in clutch
Old Sep 24, 2003 | 10:38 PM
AustinT's Avatar
Hi,
Maybe somebody has had this problem. At freeway speeds I have a bad vibration. the second I push in the clutch or put it in nuetral it goes away. Im thinking it could be the pinion angle but here is what I have
T56
spec II clutch, resufaced flywheel when it was installed
poly motor mounts and tranny
fabricated my own tranny crossmember
dennys driveshaft high speed balanced
4.10 richmond gears with zexel torson and aftermarket axels
Yesterday I replaced the draglink, idler, ball joints, rod ends and tires and had it alighned and balanced.
I have not yet replaced the bushings on the trailing arms They have a lot of play.
Any Ideas Thanks
Old Sep 25, 2003 | 10:23 PM
AustinT's Avatar
TTT
Old Sep 26, 2003 | 06:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It can't very well be the pinion; it doesn't stop when you push in the clutch.
Possible causes:
  • Unbalanced flywheel - did you have it balanced after it was surfaced?
  • Unbalanced clutch - not too likely, but not impossible, get it checked when you get the flywheel balanced
  • Bad harmonic balancer
  • Bad pilot bushing/bearing - did you change it when you put in the clutch?
Obviously, all of these things are in front of the clutch, since things behind the clutch don't change speed when you push in the clutch wile driving down the road. You can try to create the vibe with the car sitting still, by just revving the engine up to cruise RPM and holding it there; if so, it can't possibly be anything in the drive line, since all of that is stationary under those conditions.
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
