What makes the TCC unlock?
Old Sep 28, 2003 | 10:40 PM
GoonieZ28's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Transmission: ProBuilt 700-R4 & Vigilante Torque Converter
This is for the normal wiring of the 700-R4
I know when you tap the breaks, it should unlock, and also when you give it a lot of gas. When you drop to a lower speed I'm guessing it also will unlock.
Right now after my TCC locks up, anytime I let go of the gas completely, it unlocks. So if I'm going 75 on the freeway, and it's locked, and I let go of the gas, it unlocks. This is not normal is it?
I thought the ECM will read info from the TPS, and other sensors and determine when to unlock it. Shouldn't it be able to cruise for a little bit at 75 miles an hour without throttle and still stay locked up?
Could the wiring be wrong or something else, or is this normal. I know it is not me shifting into third because once I feel it unlock, I have put the car into Drive from OverDrive and then I definitely feel it shift to third... so I'm pretty sure it's the TCC unlocking.
Anyway, any help you guys can provide would be great.
Thanks.
Old Sep 29, 2003 | 12:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's normal.
Old Sep 29, 2003 | 01:51 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
It is normal... I have thru prom burning disabled the unlock of the TCC when I take my foot off of the throttle... better mpg..
Fronzizzle
Mar 18, 2019 08:29 PM
jklein337
Sep 19, 2018 06:23 PM
Roblyons
Sep 12, 2015 10:29 PM
NWAsonoma
Aug 18, 2015 05:45 PM
z28addict8490
Aug 7, 2015 08:48 PM
