Missing shifts? Read this...
Old Oct 6, 2003 | 05:38 PM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
Chevy High Performance - In the Clutch
This article describes a shifting problem due to a restriction in the hose that connects the master clutch cylinder to the slave. This is about 98 and newer clutch setups, but I found the same restriction in my hose which I purchased directly from GM. Most likely the factory setup is the same. I guage pinned the restriction at .068.
I have to replace my line anyway because the headers heated it and the pressure blew a hole in the side.
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 25, 2015 01:46 AM
crazynights
Aug 21, 2015 06:53 AM
Bryan F
Aug 18, 2015 02:28 PM
86White_T/A305
Aug 17, 2015 12:16 AM
