Eaton POSI. they ne good??
Car: for now my Jeep while im building my Camaro
Engine: building a 350 with about 440HP and 450lb
Transmission: W.C. T-5 dont know how it will hold up..
Im thinking of going with the Eaton Posi unit and upgrading to 28 spline axles what would you perfer an eaton or zexel torsen HD unit.
My stats.
350 with 420 HP and 440ftlb. will the eaton hold up or how about a zexel OEM take off from a newer camaro or a HD zexel or shoud i go with the eaton that i can get brand new for $340.
My stats.
Car: Z/28
Engine: 355
Transmission: Turbo 400
I have been using a eaton posi for many years and have very good luck with it. Its also rebuildable and tunable when it does get worn after some abuse. Check out this websight for goodies for the eaton. (www.Tomsdifferentials.com) He did my diff years ago and have zero failures outside of normal wear and abuse.
They are opening another shop back east soon. I'm in So-Cal.
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
One more vote for the Eaton. Excellant torque Bias and reliable as dirt.
Torsen great for corners...while they last....problem is they won't with big HP. Carrier just too small for the gear loadings.
Auburn a POS..at least for us Autocross\ Road Race types.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i run an eaton. i actualy picked it up on ebay for cheap, and since it is rebuildable
no worries.
no worries. Trending Topics
thanx for the replies guys this has been a major help on my decision. im going with the eaton posi. sounds like it'll be well worth it.
Dialed_In
Aug 20, 2015 01:45 PM
novaderrik
Aug 10, 2015 12:44 PM
