Need help with reverse
Old Oct 7, 2003 | 01:35 AM
firedodgeiria's Avatar
I just bought a '86 Trans Am. It runs fine, has no problem shifting or going into any of the different drive options. But it will not drive in reverse, it just sits there and revs when I try. Any suggestions would be very helpful.
Old Oct 8, 2003 | 01:43 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
if it is an automatic, u could try and see if the shift linkage is lose, or check your fluid levels, manual try fluid levels, other than that, i would have to say ur transmission is hooped
Old Oct 8, 2003 | 01:27 PM
thanks, it looks like everything has been moved up one spot, so the blank space between park and reverse is now reverse, reverse is neutral, etc.
Old Oct 8, 2003 | 08:31 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Your shifter cable is loose, stretched, or misadjusted. Pull up the center console and see what's bent/broken.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
84redta
Sep 19, 2015 09:58 AM
