T5 stops 1" short of the bellhousing??
Old Oct 8, 2003 | 07:02 PM
Scott C-2
Guest
Posts: n/a
I've been bench pressing my T5 for the last hour, but I can't seem to get it installed all the way into the bellhousing...It stops about 1" short.
I borrowed an "alignment" main shaft from a local shop to align the clutch. With a couple of smacks using the palm of my hand, the main shaft goes in snug, further than the T5. It takes a yankin' to pull it back out...I figure that's good, right? Tried this 3-4 times to make sure it is lined up right.
I then tried 3-4 times to get the trans in and it stops short each time...I try to push/force/jiggle it with all my might, but no go. It just hangs there, 1" from where it should be. The 4 trans-to-bellhousing bolts almost line up , but they are just a bit off.
Is this common? What the heck is wrong? This is a new trans with a new clutch and new roller pilot bearing. Lubed up with disk brake grease as instructed...the "alignment" main shaft went in, why won't the trans? I compared the 2 shafts and they are identical, except the T5 shaft is larger in diameter where it slides into the throw-out bearing...I even slid the throw-out bearing onto the T5 shaft and it fits fine.
HELP
Old Oct 8, 2003 | 07:21 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
The tranny should slip in without any problems, my guess is the clutch and pressure plate are not properly aligned. Realign the clutch with the manishaft (or alignment tool that came with the clutch) and keep it in there while tightening the bolts. The test shaft you have should then slide in and out easily (no hammer blows) and so should the tranny.
Old Oct 8, 2003 | 07:31 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Most likely the pilot bushing is screwed. The alignment tool should slide in easy if the clutch isnt out of whack.
Old Oct 8, 2003 | 10:15 PM
Scott C-2
Guest
Posts: n/a
The plastic alignment tool slides in fairly easily...The shop suggested using the steel shaft because the plastic ones don't always line things up right (obviously).
I'm going to take the bellhousing off, loosen things a bit, then use the steel shaft to align it all and retighten...Thanks for the suggestion!
I can't see the pilot bushing being bad as it's brand new
Old Oct 8, 2003 | 11:05 PM
laiky's Avatar
once you have the clutch aligned with the tool if you still have a problem getting the tranny to but up against the bell housing try this. getthe tranny within an inch like you did before. install the slave cylinder and have some one GENTLY depress the clutch pedal about 1/2 way. the tranny will pop right in.
Old Oct 8, 2003 | 11:53 PM
Scott C-2
Guest
Posts: n/a
I would try that, only problem is, I don't have the clutch hydraulics installed yet
That was my next step...I'm swapping from auto to manual.
Old Oct 9, 2003 | 12:07 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Did you check the alignment of your bellhousing? If your out of alignment with that, nothing is going to work correctly especially
a trans install.
Old Oct 9, 2003 | 07:21 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
I tend to think the clutch is not aligned properly. Loosen the pressure plate and realign using a steel shaft. The transmission should absolutely slip all the way in without a problem.
Old Oct 9, 2003 | 07:33 AM
Steve89GTA's Avatar
Your mainshaft isn't getting all the way in - most likely hitting the side of the pilot bearing other than going all the way in. Take it from me, make SURE everything is lined up 100%!!
I destroyed a pilot bearing, as well as my tranny's mainshaft (had to get it rewelded and then turned down.
Old Oct 9, 2003 | 09:40 AM
Scott C-2
Guest
Posts: n/a
Thanks Guys...I am going to attack it again today. I will be triple checking everything for alignment. Very glad I have the steel mainshaft to help make things right...wish I used it the first time. I really thought I had everything lined up right.
Stay tuned!
Old Oct 10, 2003 | 02:11 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Me and a buddy fought with my t5 for several hours. Wiggle Wiggle Jiggle Jiggle - still like an inch to go. Eventually everything lined up and THUNK it slid completely in if you are sure everything is alligned just play with it till it goes in.
Old Oct 10, 2003 | 03:08 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
trick is to push the clutch pedal and itll pop right in. every single time ive done a clutch thats what ive had to do.
Old Oct 10, 2003 | 03:06 PM
mike48's Avatar
Car: 89 RS (original V6 car)
Engine: 355 TPI
What type of T5 did you get? Is it a V8 or V6? The splines are different on the V6, but one thing few people know is that the V6 input shaft is about 1/4 to 1/2" longer than the V8. If you are trying to put a V6 behind a V8 you will need to very carefully trim about 1/4" off the end of the input pilot bearing surface, or the input shaft will bottom in the crankshaft and ruin the transmission. I know, I've done this conversion. I trimmed mine by taping up the journal and then using a cut off wheel in a die grinder. Cut real slow, and let it cool, or you will ruin the heat treat on the bearing surface. I've got 20,000 miles on my conversion, so far so good.
Old Oct 10, 2003 | 04:25 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I've had the exact same problem with mine in the past. I found out that it was the throw-out bearing binding (cocking)on the smooth part of the input shaft as you try to slide it in.
Just "jiggle" the clutch fork as you slowly slide it in towards the block. I must've bench pressed mine like 6 times before I discovered that!! Boy was I sore!
Old Oct 10, 2003 | 05:14 PM
Scott C-2
Guest
Posts: n/a
IT IS IN!! The clutch must not have been lined up right...
I loosened the pressure plate bolts, slid the mainshaft in, torqued the bolts to 30 ft lbs., reinstalled the bellhousing and then bench pressed the T5 one last time...it slid in like a glove! Snugged up the 4 bolts and wiped my brow...
Now, to bolt-up the beautiful new Spohn crossmember and torque arm, then the clutch pedal & slave, then switch wiring...almost done!
I need a massage...damn I'm sore
Old Oct 10, 2003 | 06:04 PM
goatman64's Avatar
Just went through this myself, complete with line-up issues as well. Finally undid everything, realligned and it went in. Incidentally, is there a recommended break-in for a new clutch? Was wanting to go to the track tomorrow night if it won't screw the new clutch up...anyone know?
Old Oct 10, 2003 | 08:03 PM
Scott C-2
Guest
Posts: n/a
Centerforce put a bright orange sheet of paper in my box that says go easy for 500 miles, then have fun...that seems like a long time to wait before going full throttle, but they must say that for a reason
Old Oct 10, 2003 | 08:56 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i had the same problem with mine, you gotta press the clutch in, and be carefull you dont bend the disc, glad you got it in, centerforce d/f is awesome, i didnt go easy for 500 miles more like 300
Old Oct 10, 2003 | 10:09 PM
Confuzed1's Avatar
Car: 83Z28 HO
Good Deal!! Let me know how ya like that G-Force!
Old Oct 12, 2003 | 04:33 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
How do you like your G-Force???
Old Oct 12, 2003 | 09:47 AM
Scott C-2
Guest
Posts: n/a
He loves it
At least that's what he told me
85 Jimmy
Sep 30, 2015 07:56 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Ranbo108
Sep 9, 2015 12:20 PM
jtwoods4
Sep 3, 2015 05:39 PM
jtwoods4
Sep 3, 2015 10:19 AM
