This is for people running 10 bolts only.
Old Oct 10, 2003 | 10:10 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I want to hear some horror stories of blown 10 bolts. List the modifications you did, slicks or street, and what happened. I want to get a feel for what they can and cannot take. I have a built 10bolt (Moser axles, really stout locker diff, 3:73 gears, and a girdle with braces) and its not broken it in yet, and I don't want to destroy it. It will be a year or two before I can afford the 12bolt or 9 inch replacement.
Old Oct 10, 2003 | 10:16 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
with the stuff listed, you could probably run low 11's high 10's with slicks without breaking it.
my dad broke an axle with a set of drag radials running mid 12's, but those were the tired stock axle. he upgraded to the 9" as soon as we got home.
my only other suggestion to add to your parts list would be to get a good set of c-clip eliminators.
Old Oct 10, 2003 | 11:13 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
like my man said above...those parts will last a while..but make sure u get some bolt in axles..even with disc brakes those c-clips arent the best..
as far as stock strenght..ive seen many LS1 T-56 cars revlimit sidestep launch with drag radials on stock trannys and rear ends pull mid 1.6 60's and low 11 passes...
talk to tim burgess on these boards...
hed pull 1.6's launching off the limiter with nitrous on with silcks on a stock T-5 and 3.42 10 bolt...11.77 with an LB9
Old Oct 10, 2003 | 12:19 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i agree c clip eliminators.
Old Oct 10, 2003 | 03:34 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Some last awhile and some dont. I've seen STOCK LS-1 cars on ET streets brake 10 bolt rears (trashed spider gear, broke axles, etc........).
So, thats why I wont run any type of drag radial / slick until I can afford a Moser 12 bolt.
Old Oct 10, 2003 | 04:59 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i fragged one on the first launch with slicks.
after that, i only ran street tires and never had a prob.
if i were you, i wouldnt run slicks or pesudo slicks (et streets, ect) until you can afford a new rear end.
Old Oct 10, 2003 | 11:56 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
355
I forgot to mention that the 355 I have cranks out 425 HP estimated @ 6000 rpm. It is a vintage 1974 Nova Custom engine (original heads 333882's, no porting, and block) with a stealth intake, M4M Q-Jet, CompCam 280H, 1.6 to 1 Full Roller Rockers, dual valve springs 135# seat (1.44's), 9.4 to 1 pistons, 2.02/1.60 valves, headers and a flowmaster cat back, no cats, and an NOS Super Power Shot set for 125HP. I also drilled holes in the back of the intake to convert to a 4 point cooling system, and run a 160* thermostat.
EGR and PVC in place.
I want to run a set of BFGoodrich Comp T/A Drag Radials.
Old Oct 10, 2003 | 11:59 PM
MiscCamaro's Avatar
where can you get a good set of C-clip eliminators that are good for street use?!?
Old Oct 11, 2003 | 08:22 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
C-Clip eliminators
Can C-Clip eliminators be installed on my moser axles without modifying them or the rear end?
Old Oct 11, 2003 | 01:44 PM
Engine: peanut LB9
moser sells them and i really like there parts.
Old Oct 11, 2003 | 03:02 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Do NOT run C-clip eliminators if you plan on side loading the axles, ie road racing or autocross. They are for drag racing only but will be OK on a street/strip application as well.
Old Oct 11, 2003 | 06:29 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
i had my 10 bolt apart 7 times this summer....i dont think there worth spending any money on...wheres all the pics of 3rd gens with 12 bolts without that torque arm
Old Oct 12, 2003 | 03:44 AM
Chris B's Avatar
I'd have to agree with Mr. Dude. I sheared 3 teeth off the ring and one off the pinion launching on the street with a set of BFG DRs. They hooked and it broke. With the equipment your have I'd say your safe to run a DR but nothing more and i woudn't try fro anything below a 1.8 short time. Yes I've seen plenty of folks go 11's on a stock rear and then I've also seen others go on the first launch. The bottom line is they wont handle repeated abuse. If your like me you'll just keep replacing ring and pinions till you can afford the big dawg. If your having to pay someone to do the gear install for you, I'd look into getting a loan cuz it wont take too many times of paying someone to equal the amount a decent 12bolt/9 inch will set you back. I also dont really agree with all the aftermarket dodads you can strap to these weak rears they may add some strength but the bottom line is you can't fix the main problem with these rears and that is the size of the gearset. Spend your money where its gonna go to good use liek a 12bolt/9 inch. IMHO
CCB
Old Oct 12, 2003 | 11:59 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
stock 305 TPI, stock 3.08 posi rear. from may to november last year: broke the posi, gears made noise at the end of the season. never ran slicks with that rear, sure glad i didnt woulda left me 2 feet off the startin line for sure.
Old Oct 14, 2003 | 10:52 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I am running 7.8's in the 1/8th w/ a 1.84 60ft on street tires. The car could launch alot harder if I had SFC's, LCA's and bracktets. IF I push it to hard the car wheel hops violently.
I have a girdle and welded tubes and thats it. I figure if I ever put slicks on it it will grenade. I hope I can get 1.75's or so on the street tires after some suspension mods. The car won't see full slicks till its gets a 12 bolt, thats a shame cause it could launch so much harder now.
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
red90IROCls1
Aug 25, 2015 06:56 AM
92camaroJoe
Aug 13, 2015 06:07 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
