Found a nice rear end. . . .
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
I was walking through a junkyard and found a Camaro that had the front clip cut off of it. I got the rear off of it and expected to just be getting a 2.73 open POS like what my car come with but I get the thing home and notice right off the bat that the rear sway bar is really thick, like double what mine is and the drums on it are aluminum and have been balanced with some kind of little round disc weights. I get the cover off and its got a 3.73 open in it (41/11). I was just wondering what did this come out of an IROC or something?? Second question how hard is it to swap out the carrier for a posi unit?? Thanks
Car: 91 Camaro RS
Engine: 350 C.I.
Ede, what should my backlash be on used gears?? The gear oil in it still looked like new, really light brown, not dark. What does L69 mean??
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
l69?
the L69 was an engine option, it was the tpi 5.0 motor, it was from like 85 and up or so,
good find you lucky duck you!
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Re: l69?
-Paul
Car: 1992 Firebird
Originally posted by cdartz
L69 is the code for a 305 H.O. carb motor. 305 TPI motors are LB9.
-Paul
Engine: 350ci
oops
my bad, i get the LB9 and L69 mixed up every time!
LB9 is the tpi 5.0 motor i was thinking of, the L69 is the 5.0 cc q-jet high output motor, as for me id like to swap in me an L98(famous 350tpi) block hehehehehe thatd be fun, heh.
Car: 1992 Firebird
Originally posted by Cronic3rd
the l69 had 3.73 gears and posi. If it has an open diff it is probably from a 6cyl or 4cyl car.
-Paul
P.S. I figured this out from looking at the '84 Pontiac dealer portfolio I got of eBay and comparing it to the PHS documentation for my car. PHS shows the WY6 package, but the '84 dealer portfolio doesn't, it's very odd and the WY6 appears to be quite obscure.
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
WS6 has read discs standard.In fact in 82 they ran out of disc rears and created a new suspension package... WS7. Which is WS6 with a drum rear. shrug.
Car: 1992 Firebird
, thanks for clearing my memory up on the discs....the WY6 had discs as well (same as the WS6) just without posi....kind of an odd package, but whatever I guess lol
-Paul
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Originally posted by quadgoat
Actually (interesting factoid..I guess) not necessarily. My '84 TA was originally an L69 car and did NOT come with a posi. It's got 3:73's but not a posi. The L69 was part of the WS6 performance package (in fact in some literature it states that you can't get the L69 without the WS6 package) which included the HO (L69) motor, hi performance suspension and posi rear with 3:73's (with the option to go for discs...I don't think they were part of the WS6, but I don't remember from the literature, since I don't have it right in front of me). The interesting part is that there was this other package - the WY6 - which was available. This is the package my car was equipped with, the WY6 was exactly the same as the WS6 except it did NOT include the posi rear end. It figures that I have the luck of getting a WY6 car and not having posi, but that's ok because I did get all the WS6 suspension stuff (bigger anti sway bars, L69 w/ electric cooling fan, etc...) Anyway, just because it's got an L69 doesn't necessarily mean that it's a posi (at least on the birds, it may well be different for the Camaros, I haven't done research on them) Anyway, sorry if that was boring, but I thought I'd share it as it's one of the little things I've found out along the way...
-Paul
-Paul
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
