help flywheel wont go on
Old Oct 13, 2003 | 06:21 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
couldnt find this post anywere so here it is..... i have a 79 350 im trying to hook it to my new t5 i just got but..... the flywheels are totaly different. what can i do to get these things to bolt up.i know the flywheels changed in like 85 or somthing,
Old Oct 13, 2003 | 07:40 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yep, you needed the flywheel I just sold to a friend. its a 2pc rear main pattern with the 153 tooth ring. can be hard to find when you are in need of one. mine came out of an 84 camaro 5-speed
Old Oct 13, 2003 | 08:00 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ok guys thanks bt i found my answer....now does anyone have one i could buy off you.lol
Old Oct 13, 2003 | 08:51 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
Centerforce sells a conversion flywheel. It's pretty expensive though.
-Rippin
Old Oct 13, 2003 | 10:50 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I've got one It was in my '84 L69 5-speed and now I've got a 350 and 6 speed. The flywheel I've got is in decent shape, I belive the only problem with it is one pressure plate bolt broken off, which shouldn't be hard to remove. Anyway, I'll be home from school at the end of the week and could get some pictures of it if you're interested. Of course it would need to be resurfaced before it was installed, but that's to be expected. Anyway, I've got one sitting in the garage
-Paul
Old Oct 14, 2003 | 10:21 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i will take it man but whats the price? just email me @ vwsuperbug74@aol.com
Old Oct 20, 2003 | 05:36 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
i know this is a coupld days old..... but NAPA, 50 bucks w/ a core.
i have an '82 Z, with a 2 pc rear main seal and 153 ring gear.
they are on '82 - '86 f-bodies with manuals
NAPA should have it in stock
Old Oct 20, 2003 | 09:19 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
You're kidding. So all the people I've seen buy this $3-400 Centerforce one could have gotten one for $50 from NAPA? Wow.
-Rippin
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
