Why no T-5 in with the 350?
Old Nov 16, 2003 | 12:27 AM
  #51
89TA383M5's Avatar
Car: 89 TA
Engine: 413 TPI
Transmission: TKO 600
I never knew that or even thought of that. Thats pretty gay but thanks for posting it. Stupid tree huggers.
Old Nov 16, 2003 | 01:21 AM
  #52
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by Tom 400 CFI
The throttle is all the way to the floor. In the carpet, as far as it will go. Maintaining that throttle position, I depress the clutch, shift gears, and release the clutch, AS FAST AS I CAN, FAST! The tires spin for LESS than half a second. No slicks here. Anyway, that's a powershift for you, text book style.
No I didn't. Here, I just "copied" and now I'll "paste":
"The T-5 is fine unless you powershift and launch with slicks"
See? I said WITH SLICKS.
Sorry about the "tone" but it's aggrivating when people talk "smack" about something that isn't really true. Of course you could "blow" a T-5 with a 305. I don't doubt that for a second. As a matter of fact, when I was a retarded punk a$$ed kid, I blew 2 of them with my 305. I'm not that punk-kid anymore, and my current T-5 works very well. Granted, I'm sure I could go outside right now, fire up my car, and destroy my T-5 in less than 30 seconds. But I'd rather run low 13's with it.
Tom,
What kind of lube do you run in your T5.
Gear Lube
ATF
other [ I was told to run straight 30w oil]
Matt
Old Nov 16, 2003 | 01:49 AM
  #53
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
the bottom line is, way more t5's explode behind stock motors than survive behind built motors.
if your gonna beat on your car, get something other than a t5.
if you have a t5 that is working behind your 3 second motor....thats great, you got lucky
Old Nov 16, 2003 | 12:00 PM
  #54
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Originally posted by Gumby
Tom,
Gear Lube
ATF
Matt
Good question and interesting theory you're onto here. I saw you mention this above, and I almost responded but then didn't. So anyway, to answer your question, I run ATF. However, I change with every engine oil change, which, due to the way I use it, is every 2000 miles. So the trans get's new ATF every 2000 miles.
As for gear oil, I heard (so this is second hand info) that the T-5 cannot use gear oil because it is "too thick" and won't "fit" between the bearing rollers and races on the main shaft bearings. The clearance -or preload- on these bearings is 0.0000", +or- 0.0001, IIRC -it's been awhile since I rebuilt one. So from what I "heard", if you run gear lube, the bearings essentially squeeze the lube out so in essence they run dry, and fail. I don't know if I believe this. I'm skeptical, but there a piece of info, accurate or not I don't know.
"anesthes", I like your post. Interesting about the manual/emissions info, but how did they get the TPI vette to pass with that joke of a 4+3, but not an F-bod? Also, under decel, V8 F-bods (and maybe other GM's) completely stop fuel delivery. The injectors shut off completely down to about 1200 RPM. How could they produce high emissions with no fuel under decel? I agree with the ease of T-5 R&R. It's cake. 40 minutes is an accurate time.
Old Nov 16, 2003 | 02:17 PM
  #55
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I believe that why I was told to run straight 30w oil.
Thicker than ATF but not to thick that it wont get in the bearings.
I trust the guy at the local yard who sold me the tranny and he said if you want it to last long run straight 30w oil.
ATF is to thin, gear lub is to thick.
But so far every time I ask about that someone say stick to ATF others say they run 80-90 with no problems.
Matt
89fast5oh
Sep 8, 2015 09:55 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
