tranny bulletin?
Old Oct 18, 2003 | 06:32 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
tranny bulletin?
I was changing my spark plugs today and stared at a sticker while it fell on my face. It says:
Before disassembly see bulletin:
CHEVROLET 89-64-78
PONTIAC 89-7-10
Call 1-800-###-####
What exactly is in this bulletin? I might call the 1-800 number, but I'd rather not do that.
It was located on the bottom of my T-5 in a '90 Firebird
Old Oct 18, 2003 | 06:45 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i can look it up for you at work on monday if nobody else gives you an answer
Old Oct 18, 2003 | 07:04 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The number was 1-800-356-7301 and its for Borg-Warner automotive. Basically, BW was trying to gauge what kind of problems were being experienced in the field, so they put the sticker on there for you to call them before the technician attempted repair. This only applied to 1988-1991 Vehicles w/ the 5-speed transmission, under factory warranty.
Old Oct 18, 2003 | 07:06 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Why wait untill Monday? You can acess all the same stuff from home as you do at work. Are you a member of the SI Forums?
Old Oct 18, 2003 | 08:25 PM
MechCD's Avatar
Engine: LO3, Vulcan
*Grins*
So I should call that number and tell them I changed my clutch out a month ago Plus I should tell them that their sticker almost landed in my eye
Thanks for the replies!
edit: I could read the phone number, but I wasn't sure if i should post it
Old Oct 18, 2003 | 09:11 PM
i will have to talk to my boss on monday and become one!
thanx for the heads up!
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
