Starter different for auto vs manual?
Old Oct 22, 2003 | 11:43 AM
HeavyBreathinRS's Avatar
Car: 1990 RS
I'm about to swap a T-5 from an 84 T/A into my 90 RS.
I already have another flywheel with the one piece seal.
Some recent classified ads I've seen on these boards refer to a "starter for an automatic"...is there a difference?
The various tech articles on the swap make no reference to this.
Thanks for any help.
Old Oct 22, 2003 | 12:27 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
i did the swap in my 1984 trans am. The starter worked fine.. Some others have done it, and the nose of the starter was to big to fit in the t5 bellhousing. YOU can just wait and see it might work.
Old Oct 22, 2003 | 01:21 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Yes there is a difference.
Old Oct 22, 2003 | 02:43 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
I only have 30,000 miles on my 84 the starter was original and when i swapped the t5 in i used the original and it fit. some fit some dont so i wouldnt say it wont work. It might.
Old Oct 22, 2003 | 05:13 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
What would the difference be?
Old Oct 22, 2003 | 06:00 PM
Tony89GTA's Avatar
Car: 89 GTA
The auto one is like twice the size compared to the t5 and the nose of the starter is to big to fit in the t5 bell housing. It might be a 305/350 thing or the production line mixed the starters (just guessing) because some guys say it does work for them, doesn't hurt to try.
Old Oct 22, 2003 | 06:39 PM
rjmcgee's Avatar
Yep, the nose on my starter was way too big. Good reason to buy a new starter.
Old Oct 22, 2003 | 06:57 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Is their a difference between V-8 and V-6 starters?
Old Oct 22, 2003 | 06:58 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well, alot of times if you leave the auto starter on and never remove it the bellhousing fits over it fine but, the problem happens when you need to change the starter you can't just slide it in the bellhousing. unless you carfully grind down the nose of it like I did. it voids the warr. but, I figured I would buy aftermarket mini starter by the time it goes out
Old Oct 23, 2003 | 08:43 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
what he said, at some point GM began using all the small starter, (according to the book at advance auto) but i do not know at what point that was.
i used the suto starter for awhile, but while in process of eliminating a bad vibration swapped it for the correct one thinking perhaps it was forcing something out of line. however it did not help.. strangely enough we rebuilt the carb and the vibe has been gone for 4 days now.
Old Oct 24, 2003 | 08:35 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
What he said.... The T-5 starter has a small body and nose. It will not go into the bellhousing if you have the engine and bellhousing assembled together. If the auto starter is on the engine and you slip the bellhousing onto the engine, over the starter nose and bolt it all up, it will fit but never to be replaced again!! You will have a tough time taking that starter back oot.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
