shifting problems
Old Oct 24, 2003 | 06:07 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
shifting problems
hey whats up
i have a 92 camaro 3.1v6 with an automatic. evrytime it shifts or i get on the gas hard i feel a large bang and my tire chirps a little bit. it never used to do that . why is it doing that . does anyone know. thanx
Old Oct 24, 2003 | 06:32 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
can anyone tell me why its doing that?
Old Oct 24, 2003 | 08:34 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Have you checked to see if your transmission mount is cracked?
When they are, under hard acceleration the back of the tranny will jump up and hit the body of the car. You should just be able to jack up one side of the car and get under there and check it out. It is between the crossmember and the transmission. Relatively cheap and easy to fix.
If it's not that, then my guess would be something with the rear end...
Old Oct 25, 2003 | 03:30 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
thanx for your help
i found out when my step dad had it that he had replaced the trans mount once before. so maybe it went bad again.hmmm. or maybe its something with the rear end.
i dunno i guess i'll figure it out eventualy
Old Oct 25, 2003 | 05:22 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
you won't find out anything unless you jack that hog up and take a gander at them mounts. Like said, not that probably the rear end.
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
