700R4 @ 8000rpm's?
Old Oct 25, 2003 | 07:38 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
700R4 @ 8000rpm's?
Will there be any problems with spinning a 700R4 at 8000rpm? I heard you need a better pump for it because the stock one with start to Cavitate(sp?) at high RPM's.
Old Oct 25, 2003 | 07:45 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
what are you spinning to 8 grand?
Old Oct 25, 2003 | 07:51 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
a built 2.8 turbo.
Maybe not 8000rpm, but at least 7500. I will set the rev limiter at 8000 tho.
Old Oct 26, 2003 | 12:51 AM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
geeze...wow....err...good luck with that one
Old Oct 26, 2003 | 05:04 AM
Pro Built Automatics's Avatar
With the Trans-Go Hi-Rev spring kit, and the Trans-Go Hi-rpm No-Yo-Yo front pump steel rings & spring setup, it will hold up to 7,800 rpm.
Old Oct 26, 2003 | 09:10 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
ok cool. Is there anything else that would be needed to beef it up some more? Im only planning on running about 250hp through it daily, but on the occasion i want to go to the track I need it to hold up to 400+
Im not very knowledgable in the transmission deptartment, just engines.
Old Oct 26, 2003 | 09:12 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
because its a V6?
I laugh at your Overwieght, Underpowered excuse for an engine you like to call "a V8"
or are you just refering to the 700R4 being able to handle 8K?
Old Oct 26, 2003 | 10:10 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
How can you call a V8 "underpowered" when its you that needs a turbo to acheive a 250HP daily driver.
Even if you do reach your goal of 400+, V8's can do that N/A.
The only advantage your V6 has is a mere few pounds in weight savings, which hardly offsets the loss in displacement. That and the $3 savings in spark plugs when a tune-up is needed.:lala:
But to answer your question, the parts Dana listed will help keep the transmission out of trouble, but you still need to upgrade many of the internal components. Your V6 tranny stock only had 5 clutches in the already ailing 3-4 setup.
Old Oct 26, 2003 | 11:17 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
i dont need a turbo to make 250hp, i just need it to make 400+
So about the tranny, is there like a kit or something that will come with all the parts needed to make it handle 8000rpm's and 400+ hp? Or do i have to buy all the parts seperatly?
Old Oct 27, 2003 | 12:13 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
*** forbid someone build something besides a small block chevy People builiding different things is what makes this hobby and these boards so interesting.
Old Oct 27, 2003 | 01:42 PM
x_wolf's Avatar
Car: 91 Camaro RS
its not that someone isn't building a small block. I would just think that for money involved, it would be cheaper and easier to build a turbo'd V8. there isn't anything wrong with wanting to build a V6 or anything, but to go as far as to call a V8 a piece of crap....no don't think so.
Old Oct 27, 2003 | 02:44 PM
Go to http://www.pro-built.net/index.cfm?f...ct&productid=5 this will give you everything you need to do this right.
Old Oct 27, 2003 | 03:44 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Damn guys chill out with the flaming i think it was just a joking comment...Take some Prozack
Old Oct 27, 2003 | 05:10 PM
x_wolf's Avatar
Car: 91 Camaro RS
mmm...prozack....nummers...makes you feel good
cheers
Old Oct 27, 2003 | 05:29 PM
LilJayV10's Avatar
Engine: 406 Roller
Old Oct 27, 2003 | 05:53 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
He's not making up the part?
"Trans-Go Hi-rpm no-yo-yo"
All I pictured was some rapper with his bball cap on sideways doing the "yo yo mtv trans-go" stance...
Old Oct 27, 2003 | 06:07 PM
AAAAAAAAAAAAAAAHHHHHHHHHHHHHHHH
HAHAHAHAHAAHAHAHAHHAAHAHA
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
