T-5 tranny question
Old Oct 27, 2003 | 07:12 PM
JRupert99's Avatar
T-5 tranny question
Alright I have been reading on how the t-5 is a weak motor and it seems that it is not recommended for a 350 which I had planned on putting into my car in the late spring early summer of next year. I do not want to put a weak tranny into my car but I do want to keep it a stick if possible. My possible hp out of the 350 will range from 330-400hp. I have two camaro's one is pretty much a parts car being an 88 with a t-5 and my current 2.8 with a t-5. I had planned on using the one out of the 305 but I dont know if there is a difference in the trannys I have now or not? So basically what I am asking is if there is a difference in the tranny's I have, and What would be a nice setup for a 350 with the hp given?
Rupert
Old Oct 27, 2003 | 07:13 PM
JRupert99's Avatar
sorry not a weak motor, but tranny...
Old Oct 27, 2003 | 07:14 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
I think the input shaft is deffrent.. (think)
The best I find.. is to buy a World calss T-5.. and
rebuild it with the G-force kit.
Straight cut gears... plenty strong
Old Oct 27, 2003 | 09:15 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
I've got a WC T5 for sale for $300. It's got almost everything included. PM me.
-Rippin
Old Oct 27, 2003 | 10:08 PM
ZZ405's Avatar
Car: 89 IROC
Engine: ZZ4
Is there anything wrong with the t5 behind the 305? If you don't beat your car mercilessly that tranny would be fine at that power level. It all comes down to how you drive it.
Old Oct 28, 2003 | 12:50 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Not straight cut though. Just not as much of an angle, and the gears themselves are a little wider. At least, in the synchronized G-Force gearset.
They do have a "Dog ring" type that's straight cut, but It's pretty much for strip use.
There's also a Tremec TKO or a T-56.....also good trannys, but T-56 being the weaker of the three. If you don't drive it like you stole it all the time, the WC T-5 will take quite a bit more abuse then people give them credit for.
Old Oct 28, 2003 | 12:09 PM
JRupert99's Avatar
The tranny behind the 305 needs to be worked on. I was told it needs some kind of fork and a few gears replaced, would this be the time to get something custom done to it and what would that be. Like a good setup and how much it may cost
Rupert
Old Oct 28, 2003 | 06:06 PM
JRupert99's Avatar
Also, I do not intend on beating my car to death. I want the V-8 with power for more show than racing. I may occasionally being 4 times a year race someone at a light . But I just want the sound of a V8 and to let other people know that I have it. So beating the tranny to death is something I am not worried about. The WC tranny you all talk about is it just the t5 I have in the 305 or is it basically the same but with some mods done to it?
Rupert
Old Oct 29, 2003 | 06:00 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Your 88 should be a WC. 88 Was the first year for them. WC just ment that Borgwarner redesigned them to handle more power. here is a good web site to explain the differences.
Look at item 22
http://garage-scene.home.att.net/t5_install.htm
Cacike
Aug 27, 2015 05:10 PM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
