Stock length driveshaft useable for T56 swap???
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
I was wondering if you need a custom driveshaft to change out a 700r4 for a T56.
I decided on installing a T56 instead of building my 700r4 because my Dad just bought an LS1 with the Trans out of a Vette and he doesn't want to use it.
I think this will be cheaper anyway.
If the stock driveshaft does not work, how about the ones out of the fourth gens???
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
The drive shaft will work fine.
But if I understand your post correctly, you are going to use a 'Vette Trans? Those are Transaxles. I have never done this swap, but I'd imagine that you're going to need a bunch of parts to make it work, IF the basic trans housign is even the same...
Car: 91' RS
Engine: Built 355
Transaxle????
From what I hear, I need a LT1 bellhousing cause the LS1 bellhousing will not bolt up to a regular small block.
Engine: LT1, L400
A 2000 LS1 corvette has the trans located in the rear of the vehicle, as a transaxle assembly. The trans does NOT bolt directly to the engine.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Transaxle????
Originally posted by 330hp_91RS
I am using a T56 out of a 2000 or so Corvette that is mated currently to a LS1 motor.
if you have a trans bolted to that motor, then your dad got ripped.
its a Fbody motor.
the LS1 T56 has a diff input shaft and cannot be used with the LT1 clutch stuff.
you need to either modify that trans for it to work (and then use LT1 stuff) or get a LT1 tranny.
Car: 91' RS
Engine: Built 355
Re: Re: Transaxle????
its a Fbody motor.
its a Fbody motor.
He has all the clutch stuff except for the master/slave cylinder and pedal assembly.
What do I need to make it work on a regular small block????
I figured I'd need a bellhousing anyway.
ALSO: How do you figure my dad got ripped when LS1's are pretty much the same in Vettes and F-bodies??? BTW: he got the entire setup out of a 2001 Vette with under 20k on it for under $4,000. W/ computer and sensors etc.
Engine: LT1, L400
Whether or not your dad got ripped, the T-56 in a 'Vette is not bolted to the engine. The engine and trans are seperated by about 4 -1/2 feet.
Can you post a pic of the thing?
Car: 91 Camaro Vert
the C5 corvette has a Torque tube running from the engine to the back of the car.
the rear of the car has a transaxle. there is no tranny.
Car: 91' RS
Engine: Built 355
uhhh.....
My dad probably has the T56 standing alone without all the trans axle crap you guys are talking about.
Sorry that I said it was bolted up to an LS1, what I meant to say was that the engine and trans are both out of a vette, What do I need to make it work????
I need to know what will be less expensive, fully rebuilding my 700r4 w/ a new converter, or this T56 swap.
Engine: LT1, L400
Re: uhhh.....
Would you guys read my last post before you repeat what you already said??? NO. I cannot post a pic of this cause it is in HAWAII. I am in CALIFORNIA.
Car: 91 Camaro Vert
Re: uhhh.....
getting a T56 + other misc parts out of a local LT1 car will be ALOT less expensive.
the trans in the vette is NOT a T56. some internals are the same though... so if you went out and got the right casings and rebuilt it all in that case, and got the right input shaft, ect... that could work... then you just need the rest of the stuff from a LT1 T56 setup.
or you could take out your rear, cut the floorpan, custom fab some way to mount the transaxle, make acustom rear suspension, have someone fab up a way to connect the TQ tube to the small block chevy..... and you would have a C5 vette transaxle in your car...
this is all after you pay for it to be shipped from hawaii of course.
Car: 1989 IROC-Z
http://corvetteactioncenter.com/cgi-...5.jpg&img=&tt=
there is what youre gonna be dealing with. im not saying it cant be done, but why bother when you can get one from a 97 LT1 equipped car and put it in? just my 2 cents.
Car: 91' RS
Engine: Built 355
Re: Re: uhhh.....
Car: 91 Camaro Vert
Re: Re: Re: uhhh.....
No shipping. The motor and trans are sitting next to my Car , IN Hawaii. I can get all the rest of the parts in state too, no problem. Looks like I'm gonna just build the 700 though, less hassle.
for the price of a performance build of a auto, you can swap a T56 in.....
just use Lt1 car parts..
its your car, your call.... manual or auto... if you really want a manual, you're never going to be happy with a auto..
Car: 86 Iroc-Z28
Engine: FB385
Listen to the Man!!! I wanted one but went with the built up 700. Now i find myself looking for "deals" so that maybe i can sell my set up and get a manual. If you want to sell what you have in HI, maybe you can get this much!? http://cgi.ebay.com/ebaymotors/ws/eB...tem=2445610530 Assuming that is what you have there.
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Sell it and buy a 94-97 T56 from an f-body, you may even get a reputable salvage yard to trade you one with hydraulics and flywheel for it. Actually, for what a complete vette T56 transaxle setup would bring you if you sold it....you could buy a blueprinted D&D T56 which is based off of a Viper T56 and modified to fit 93-97 f-bodies (which is what we use for swaps). They're pretty much bulletproof. I've never been impressed with the T56's after Tremec bought out Borg Warner (around 97). The ones after that that went behind LS1's just don't generally hold up to as much as the ol LT1 versions. If you were going to modify an LS1 version to fit your motor....you'll spend alot more that what you realize to make it happen.
Car: 91' RS
Engine: Built 355
To end all of this....
The trans is actually an F-body trans come to find out. My Dad had no idea the corvettes were setup like that and all. The guy he bought the setup from knew the vette trans was not going to work and gave him an F-body one but my Dad told me the whole she-bang was out of a vette.....anyway it was a bunch of mis-communication- LOL. I was yelling at my dad and saying " does it have a regular freakin tailshaft or what???" LOL.
Car: 91' RS
Engine: Built 355
He did not get screwed...
Originally posted by 90formula5spd
you should use the VIN to find out whether he did get screwed or not...
My Dad also said he saw the car the motor came out of.
Anyway, who cares if the motor was out of a vette of not??? My dad is putting a LS6 cam and intake in, as well as a diff throttle body. The truck will have Long Tubes and a nice dual exhaust as well as easy provisions for a real cold air intake.
The truck will weigh about 2000-2100 lbs. with the new motor in it. I would estimate the motor to put out at least 450hp.....and he's going to either get a magnacharger or a 9psi ATI blower for in the near future.
Car: 1989 trans am
Engine: 357sbc
well alright, thats good i guess but the corvette engines did put out more power than the F-body ones did, thats why it matters, but i guess... sounds like he will have a fast truck, should put it in a car though!
Car: 91' RS
Engine: Built 355
Heh...
The roofline in actually lower than a camaro's and you can't put anything in the bed cause there isn't one. The roll cage actually comes out of the cab and down into the bed, looks awesome. There's prostreet rubber in the back with a 4 link and at least 5 inches of tire is tucked under the rear fender. It's got suicide doors, and the seats are out of a newer Muctang GT.
When I go home I'll take some pics for you guys.
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
tremec t-56 swap you need to shorten the driveshaft by 2'' or get a new one, if you have an Auto trans. I would think an LT1 or LS1 t-56 would be about the same, shorten by 2'' or have one made. tremec and GM units are almost the same in most respects.
Car: 1989 trans am
Engine: 357sbc
is it like a custom truck or what make is it? sounds cool, but im not into trucks so i wouldnt want one like it, how much money has he thrown into it? what kinda tranny does he have in that beast?
You CAN run LS1 T56 behind a gen I small block
With regard to the viability of the project, if the T56 is an LS1, you still can run it: It requires a special bellhousing however, and you probably will need to shorten your driveshaft by about 3/4".
I just did this swap in my '90 GTA. I used a Weir Hotrod Products bellhousing, but I believe the new McCleod bellhousing will also now accomodate this swap.
With the Weir setup there is no need for a special LT1 style clutch set-up. I ran the same clutch set-up as I was running with my T5. I changed the hydraulics over to the LS1 clutch however. The Weir bellhousing does not accomodate the externally mounted slave. A hydraulic throwout bearing is used instead--the same thing as the LS1 guys run.
Everything bolted up fine, except for the driveshaft. The LS1 has a longer input shaft, and that extra length means that the driveshaft has to be shortened accordingly. I believe the difference is 5/8", but 3/4" is probably a safer number to use.
Also, if your driveshaft is like mine, there may be an extra charge to machine the end of it down: GM flared the end of the tubing and put a corresponding taper on the driveshaft end. Since the shop could not reproduce the flare they had to machine the taper out of the end in order to fit it into the shaft before welding. This should not pose an obstacle--just be aware of it.
Apparently it is an F-body tranny
About a dozen posts back he said that while the engine is from a Vette, the seller actually included an F-body tranny because he knew the Vette unit would not work for the application. He just wasn't explicit about what he was selling. Tried to be considerate and just confused everyone. No good deed goes unpunished
One detail I forgot to bring up about using the LS1 T56 is the mount is also affected by that extra 5/8". I used a Spohn crossmember and had to redrill the mount holes farther back. There was just enough material to get away with it. I also had to trim about 3/4" of material off the bottom of the tailpiece of the tranny in order to get it to sit down on the mount without interference. Again, not a major obstacle, but be aware of it.
Also be aware that connecting the clutch master to the pedal can be a challenge. I suspect that the best solution is to use 4th gen pedals. I have seen that some guys are doing that, and I suspect this is why. The 3rd gen clutch pedal is not designed for either the LT1 or LS1 master. I have a lathe and a welder, and that allowed me to make a new pivot and weld it to my old pedal. Lacking that, I do not see a safe, secure way to attach the master linkage to the pedal. The stock pivot on the 3rd gen pedal is too short to use anything that I could dream up.
1992 Trans Am
Aug 8, 2015 08:16 PM
