stripped trans cross member nuts
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
well yeah, somehow both of the trans x-member bolts got stripped. how can i fix this? i cant think of anything else but to tap the holes to 7/16. i believe they are 3/8 threads now...
both of the holes are on the same side too, so i need to get them fixed. they are on the left side.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: stripped trans cross member nuts
Engine: carbed L98
wow, so i guess this happens a bit? i thought to myself how could i possibly strip these things!
lol. glad to hear its been done. did you both drill and tap to7/16ths? or can you jsut tap it directly. i got some extra bolts (those bolts that connect the trans and the bell housing together) that ill probably use.
lol. glad to hear its been done. did you both drill and tap to7/16ths? or can you jsut tap it directly. i got some extra bolts (those bolts that connect the trans and the bell housing together) that ill probably use. Supreme Member
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Those bolts that connect the trans and the bell housing together are metric (M10x1.5, same as the original crossmember bolts), and will strip out again if you tap the holes with a 7/16" tap. There's not really enough meat on the 'nuts' to go much bigger, as it's actually a piece of stamped steel inside the framerail.
Pete
Pete
Engine: carbed L98
Pete
Pete
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by melamkish
I used a heli-coil kit when I had a hole strip out. Hardest part was getting the car high enough to get a drill under the car.
yup.... i havent done it to my car, but when i was in high school, a kid doing a clutch (or somthing) stripped out the threads to his firebird
i ended up being the one who had to teach him how to drill and heli-coil it......
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Stripped threads for trans cross member
I had the same problem. I kept ripping the bolts out at the dragstrip using Nitrous. What I finally did was retapped the the threads and put a 7/16 helicoil in and then welded the bolts head to the crossmember. Have not had a problem since. he only problem is if you have to take your trany out for some reason make sure you have access to a welder or hot enough torch to undo the weld. Oddly enough that is what I'll probally be doing this weekend. I think my Torque is going. Oh well this was one guys solution to the problem.
CALIROCZ8
CALIROCZ8
Car: 91 Camaro Vert
Re: Stripped threads for trans cross member
CALIROCZ8
CALIROCZ8
ummm.... why dont you just put a stud in there, attach THAT, and then bolt it to the stud?
1992 Trans Am
May 10, 2023 07:19 PM
