clicking aluminum driveshaft
Old Nov 13, 2003 | 07:55 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
A few weeks back, I installed an LS1 driveshaft in my RS. It cured the high speed vibration, but in its place created another semi-annoyance.
Whenever I take off from a stop, it makes a 'click' sound (sometimes a couple) that sounds like metal when it is being stressed or a light 'tap' on the shaft. It's not very loud, but it is audible. Whether I'm accelerating slowly or mashing the pedal, same noise. When I shift into reverse, it does the same thing. Nothing is hitting or rubbing on the driveshaft (or even close to it, for that matter).
Has anyone else experienced this with an Al driveshaft? Would a bad u-joint possibly cause this? I'm not getting any other symptoms of a bad u-joint (intermittent vibrations at certain speeds, etc.), but I don't want to rule anything out.
Old Nov 13, 2003 | 10:21 PM
onebinky's Avatar
My guess is with the U-joints. Alot of the times, the only symptom you will get is the clicking, or a squeeking noise. Put the car up in the air and see if there is any play in them. If there is, it's time for new ones. If you do have to replace them, get the greasable type. As long as you keep up with them, they will last you alot longer.
Matt
Old Nov 14, 2003 | 11:17 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i work at a chevrolet shop and and alot of 1998-2000 f-bodys driveshafts make that noise it is coming from the inside of the driveshaft is ok but you will hear that noise i think it was a gm bulletin on it.
Old Nov 15, 2003 | 09:17 PM
Thanks, antoine, for the peace of mind. Anyone know the best place to look up GM tech. bulletins? Is there a good 4th gen. ( ) board that might have this information?
RS Reaper
Oct 17, 2018 07:52 PM
Linson
Oct 1, 2015 09:50 PM
