Can't downshift into 3rd from 4th or 5th?
Old Nov 28, 2003 | 03:46 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
It upshifts fine, no resistance or anything. But when trying to downshift from 4th or 5th, it will not engage until I get to ~15 miles an hour. If I go down to 2nd and, of course, do not let off the clutch, and then go back up to 3rd, it engages fine. What is this? Does this mean it's time for a T-56? TIA...
Old Nov 29, 2003 | 06:39 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Synchro is worn and can't bring the pressure plate up to speed. I bet if you kept the clutch in and held steady pressure going into 3rd it would eventually "sink" into gear. That'll wear the synchro even more though.
Old Nov 29, 2003 | 08:17 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
try double clutching it - should work fine - clutch in - go to neutral - clutch out - rev motor in neutral - clutch in - go to lower gear - clutch out - continue down road w/out having to buy new tranny just yet
Old Nov 30, 2003 | 02:53 AM
HM Murdock's Avatar
Yeah, i did that a couple days ago, worked fine. I'm kinda looking for an excuse to do the T-56, though...
tyeo098
Nov 30, 2015 06:27 PM
327IROC85
Sep 23, 2015 12:11 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
DARKmj16
Sep 9, 2015 04:07 PM
rudolphschenker
Sep 4, 2015 02:41 AM
