What VSS is right for me???
Old Nov 28, 2003 | 07:12 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
My speedo does not work when my car is cold after 20 mins of driving then my speedo picks up and shows my speed. Does this sound like the VSS is going bad? All the othere guages work. Any ways i called GM and there are 3 different VSS for my year car. I then called Autozone and they only showed 1 in there computer.
I have a 1991 Camaro RS V-6 3.1 with a 700-R4 110 MPH Speedo.
Would the one from autozone work or will i have problems with it because gm has three different ones for my car. If any one has replaced theres how did you find out what one you had. And how hard are they to change.
Old Nov 29, 2003 | 11:55 PM
FAST RS's Avatar
anyone?
Old Dec 3, 2003 | 07:07 PM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
you have a magnetic pick-up speedo right? 90'-92' . if GM has a part for you give them your tranny code or the vin or find your build sheet and see if they can help you with that info. GM discontinued the 85'-89' electric speedo vss in 1997. i know cause i tried to find one and they told me, your sh*t out of luck.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
