Flywheel for Auto-T5 swap... HELP!!
Old Nov 29, 2003 | 03:55 PM
Vidman's Avatar
Car: '86 Iroc
Transmission: T-5 with Pro-5.0
Hi guys...
I am swapping a t5 into my 86 iroc and the t5 came out of an 84 bird with a 305. When I went to put everything together, the flywheel from the bird is a heavy one and the one off the Iroc is really light and has a weight on it. Of course I was going to use everything off the bird so it'd match, but since the bolt pattern is different can I just use the light one with the t5? Thanks for youe help!! Couldn't have done this swap without you guys!!!!
:yourock:
Old Nov 29, 2003 | 09:30 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
well if your car had an auto trans to start with you have a flexplate not a flywheel which is really light.....the flyhweel should weigh around 30lbs regardless of the year if it came out of a 3rd gen
Old Nov 29, 2003 | 10:36 PM
Vidman's Avatar
Car: '86 Iroc
Oh... So now I need to go find a flywheel for a one piece rear main seal? Is this correct??? Guess I can't just use the flexplate....????? Thank you!!!!
Old Nov 30, 2003 | 12:53 AM
Car: '91 Camaro RS
a flexplate has big holes in it usually.....and flywheel is solid steel and looks like a huge brake rotor, with 6 bolt holes around the circumference
think about whats going......the clutch disc is sandwhiched between the flywheel and the pressure plate.....it rides on the surface of the flywheel
Old Nov 30, 2003 | 07:21 PM
Vidman's Avatar
Car: '86 Iroc
Yeah, I see what's going on now. Just learning all this stuff. Guess I'll go try to find a flywheel for a one piece rear main seal tomorrow! Thanks!!!!
Old Nov 30, 2003 | 08:45 PM
Car: '91 Camaro RS
no problem
Old Nov 30, 2003 | 10:19 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
The flywheel for a 1 pc rear main block is externally balanced, sor you're looking for a 153 tooth external balance flywheel.
Old Dec 3, 2003 | 09:20 AM
Vidman's Avatar
Car: '86 Iroc
OK thanks! If i find a flywheel for a 1 pc rms can I assume is externally balanced? I think I found on online, but it doesn't say internal or external, but it is for a 1 pc rms. Thanks again!! Couldn't do this stuff without you guys!!!
:yourock:
Old Dec 3, 2003 | 09:35 AM
85TransAm406's Avatar
Car: 1985 Trans Am
all of the 1 pc seal flywheels are balanced the same, unless they are for a 383/400 crankshaft that hasn't been internally balanced.
Old Dec 3, 2003 | 11:55 AM
Vidman's Avatar
Car: '86 Iroc
85TransAm406...Thanks from coastal NC!!! Good to see more thirdgens around!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Gordonr1973
Sep 29, 2015 11:59 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
