Gear Identification
Old Dec 1, 2003 | 01:00 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Gear Identification
I just bought an 86 iroc with the 9 bolt rear end. Without jacking the car up and testing it, is there any other way to determine the rear end ratio? I know on the 10 bolts there is an axle code beside the diff, is this true on the 9 bolt also? Is there an RPO for each gear size? I think the only RPO is the G92 for perf. axle ratio, but mine doesnt have this.
Old Dec 1, 2003 | 01:08 PM
ede's Avatar
ede
only way to know for sure is to pull the cover and do the math
Old Dec 1, 2003 | 03:53 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
my 9 bolt has a tag that says "BW 3.27"
but the only way to be sure is to pull the cover off and do a little division....
Old Dec 1, 2003 | 04:02 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If you do some math you can mark a tire and then roll the car forward one turn, while someone counts the times the drive shaft turns the yoke,.You can get a real good guess.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
