Need info on TV boost valve installation
Old Dec 2, 2003 | 08:32 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Well the subject pretty much says it, does anyone know anything about how to do this, I've got a .500 valve and zero idea where it goes and how to install it. Thanks.
Old Dec 14, 2003 | 09:31 AM
Nordbert's Avatar
TV valve lineup
There is a snapring on the bottom of the pump by the filter inlet that is the same size as the TV valve. The TV lineup is above it.
If the TV valve won't come out with a magnet, you may have to put the pan back on and fill with ATF, start the engine and run the
transmission through the gears. The pressure should blow the TV system parts into the pan. I've never done this, but it has been done by some on www.turbobuick.com. I've read that it is very hard to put it back into the pump while the trans is in the car.
Imagine that!! BTW, make sure you have the right size of snapring pliers, a filter kit, and a case of fluid on hand.
Old Dec 14, 2003 | 11:54 AM
MizfitCreations's Avatar
Car: 87 Camaro LT
Engine: ZZ4, AFR195, XR276-HR
Transmission: 700R4, Transgo
yes, it can be a little stubbor to get in, but it will go. I just stuck my finger up there and kept pushing it up a tad untill it came out. Also, make sure that the snap ring is locked in place when your all done. Mine wasn't and I got about 3 parkign spaces before it blew out into the pan, thus proving the theory above
Get with me at one of our meets and I'll bring the video if you want to see how its done.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
toronto formula
Nov 10, 2015 06:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
