which better 9 or 10 bolt
Old Dec 5, 2003 | 03:36 PM
OldsmobileGuy's Avatar
which is better to build an 86 9 bolt or a 90 10 bolt
and what about a 96 10 bolt would that fit under a 90 iroc?
guys at my shop
Old Dec 5, 2003 | 05:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which has more parts and gear ratios to choose from, for less money? 10-bolt.
Which will last longer after you get it together? 9-bolt.
Old Dec 5, 2003 | 05:21 PM
ede's Avatar
ede
like five7 said a lot depends on how you define best
Old Dec 5, 2003 | 07:56 PM
well he wants it to last and he's got cash and a built motor which is stonger?
Old Dec 5, 2003 | 07:58 PM
five7kid's Avatar
12-bolt from Currie.
If he's got cash, nothing else makes any sense (unless it's a 9-inch from Moser - but then it's not GM).
Old Dec 7, 2003 | 03:10 PM
well i is a 9 bolt and its a gm thing from AUS thats all i know :lala:
Old Dec 7, 2003 | 07:14 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Check out www.9bolt.com He sales parts for them and he has a link to an Hot Rod Mag Article talking about the strength of a 9 bolt.
I think 4th gens were different widths. I'm not for sure though. Just concluded that since the backspacing on the rims are different. I'm sure if you did a search you could find info. I've read something about that on here somewhere.
Old Dec 7, 2003 | 08:55 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have broke them both :-)
now i have a 9" moser
Old Dec 7, 2003 | 10:49 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
the 96 axle will fit under the car and blot right in but in order for the wheels to clear properly you need to use 4th gen wheels because the 4th gen axle is wider than the 3rd
Old Dec 8, 2003 | 01:04 AM
bigals87z28's Avatar
Car: Check The Sig
....dam wide a$$ed 4th gens... couldnt just keep it simple.
Old Dec 8, 2003 | 01:23 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
As said above, its really a toss-up. You could fork out the massive amounts of money on a 9-bolt or you could build and break 2 or 3 different 10-bolts and still be even (money wise). Even then both will probably break eventually. Wanna do it right might as well fork out the cash for an aftermarket 9" or 12bolt
Whoever told you that was wrong. Yes they are wider (1" I believe?) but that will not cause any problems with your wheels.
Old Dec 8, 2003 | 02:12 PM
five7kid's Avatar
Just to be clear:
A 9-bolt is the GM Ausie rear.
A 9-inch is a popular high-strength Ford rear. They are available from Moser for 3rd gen F-bodies.
Old Dec 9, 2003 | 11:10 PM
Car: 89 Formula
well i dont mean to feed the fire but im asuming alot of the people using this board have a larger size tire than normal and or have a lowered suspension so all these things combined with putting your wheels out 1/2 inch or more than there suppossed to be could just maby result in a few clearence issues but i dunno i could be the fool
Old Dec 10, 2003 | 10:13 AM
Parrydise7's Avatar
Adding to what fire... had to say about 9bolt.com, Miles has a 427 feeding in to his 9 bolt. I guess the 9 bolt isn't as strong as a Dana 44, but it will still take quite a bit of abuse.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
