700r4 line pressure
Old Dec 7, 2003 | 06:28 PM
badCHEVELLEman's Avatar
Car: chevelle + camaro
Engine: 520hp 350 350
Transmission: th 350 700r4
Axle/Gears: 4:56 3:23
700r4 line pressure
what it the line pessure suposed to be in a 89 700r4 just put it in and want to make sure the tv is adjusted right
Old Dec 7, 2003 | 06:46 PM
radiateu2's Avatar
Go here www.700r4.com
Old Dec 8, 2003 | 01:07 AM
Pro Built Automatics's Avatar
Make sure the TV cable is tight at WOT, then you will have max imum line pressure. The TV cable should never have more than a 1/16" play at WOT, or damage could be done to the transmission.
Old Dec 8, 2003 | 06:54 PM
700r4 line pressure
is that all you do to adjust the tv cable is to make sure its tight at wot???
Old Dec 8, 2003 | 07:00 PM
radiateu2's Avatar
You can do that until you have a pressure guage to do it right. Its better to have too much line pressure than to little. A pressure guage is what you need to do it right and the 700r4.com has the guage and instructions you need
jklein337
Sep 19, 2018 06:23 PM
Andrew6.688
Dec 13, 2015 10:59 AM
g.l.mos
Aug 22, 2015 12:02 AM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
