home made posi?
Old Dec 9, 2003 | 03:25 AM
SeanTimothy's Avatar
home made posi?
i saw on monster garage ...thatthey welded the gear cluster togather some how and formed *posi* or whatever you wanna call it.....was just currious if thkis worked on our cars....not hat i wanna do it, or think its safe.....just wondering if it really worked
Old Dec 9, 2003 | 04:53 AM
ede's Avatar
ede
sure it'll work, how long it'll last is another question, how pratical is it is even a bigger question
Old Dec 9, 2003 | 04:54 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
DON'T DO IT!!!
Welding the gears together would be fine if you were doing it to a bomber or street stock (roundy-round dirt track) but not the street. If you do it on a street car you are looking at bad wheel hop around corners, excesive tire wear, and broken parts.
DON'T DO IT!
If you are looking for an inexpensive quick "posi", first cruize the bone yards for a used rear end. Who knows, you might find one with a nice 3:23 or 3:42 gear in it. If you don't find anything there and are not concerned with a gear change, and the rear end on your car is in good shape, then buy a Powertrax.
Old Dec 9, 2003 | 06:53 AM
noo i wasnt gonna do it, i was just wondering if it worked.....
Old Dec 9, 2003 | 06:26 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It works, but only if you want to go striaght. When you turn your posi will de-couple and allow the outside wheel to turn more than the inside wheel that is sorta pivoting.
Old Dec 9, 2003 | 08:01 PM
EvilCartman's Avatar
Car: '82 Z28
Ahh good old lincoln locker I've seen a car break on the street running a welded up rear end, not a good idea.
Old Dec 9, 2003 | 08:07 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
welding them up is a great way to get traction for them muddy demolition derbies.
Old Dec 9, 2003 | 08:11 PM
SuperchargedRS's Avatar
Car: Camaro of course
just buy a spool, or mini spool. It ties it all together hence doing just what you were talking about.
http://store.summitracing.com/partde...=MSR%2D5S9F31A
-SuperchargedRS
Old Dec 9, 2003 | 09:44 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
all they did was weld the spider gears together so they couldnt walk around, which locked the two axles together.
Old Dec 10, 2003 | 06:16 PM
iroc22's Avatar
4x4'ers do it all the time. I think it's stupid but apparently it is perfectly safe to them.
The main reason for breakage is the uneven heat distribution when welding. It severly weakens the gearset and other components. welded spiders + rain = ditch. It's called a differential for a reason
Old Dec 11, 2003 | 09:06 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
not a single person here hit on the big problem.
first off, lets talk about how the axles are held onto the diff.
theres these little C clips.... on the inside ends of the axle.
these are the only things holding your axles (and wheels) on.
if the axle were to break anywhere along its length, the wheel would come out and off.
locking it like that on the street makes it overstress the axle... eventually it WILL break. not a good thing.
i watched a guy do it back in high school.... sure enough a couple weeks later, i was there to watch the tire fly out and him smack the wall at cooper dragway. fun!
somewhere on here is a nice pic of someone whos axle broke and they coasted to the side of the road.... the axle is out a foot or so....
Old Dec 11, 2003 | 08:45 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Even with out a welded diff, the wheel would still roll away if the axle were to break with a c-clip rearend...
I saw it happen once at the track, that sucked, they had to shut that lane down for a while to clean all that crap up!!!
I would weld the diff if I was planning on taking the car out for one last fun night before I set it on fire!!!
morrow
Jan 13, 2024 12:29 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
z28guy134
Sep 1, 2015 11:50 PM
TheExaminer
Aug 26, 2015 04:59 PM
