Axle end bolt pattern ?'s
Old Dec 14, 2003 | 03:53 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I have a chance to pick up a 3.42 10 bolt out of a 92 Camaro for the Formy, but, it was a disc set up and I have drums. Are the four bolts on the end of the housing spaced the same or am I out of luck? I'm hoping I could remove the caliper brackets and just swap over my drums. TIA
Old Dec 14, 2003 | 07:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, they are completely different. The disc thing is a small flange with 4 bolts; the drum one is a tall thin flange with a big hole at the top for the wheel cyl, and a couple of little screw holes for the backing plate.
People say you can modify a drum flange to hold disk brakes. But I fail to see how that's possible, having had rears of the 2 types sitting next to each other.
The 92 disc setup (unlike the 89-back system) will just bolt up to a drum car and work fine. I'd recommend leaving it all alone and just putting it on your car.
Old Dec 14, 2003 | 07:39 PM
watajob's Avatar
Car: 92 T/A 'vert
RB:
No need to change master cyl., prop.valve, or e-brake cables? BTW, it's supposedly off a B4C car. Are those the big discs or the regular ones? And, if it is, will it still work as you say?
Old Dec 14, 2003 | 09:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes those would be the ones with the larger rotors, and the aluminum PBR calipers.
In at least some of the years the PBRs were used, the same MC and PV were used on both drum and disc cars. So it seems safe to assume that the hydraulic requirements of the PBRs are fairly similar to those of droms.
I have a PBR rear on my 83 right now, with the OE MC & PV that came with its drum system. Seems to work just fine.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
red90IROCls1
Aug 25, 2015 06:56 AM
