Weird problem in reverse
Old Dec 19, 2003 | 09:55 PM
Bandit5's Avatar
When I am in reverse, and I accellerate any more than a crawl, the whole rear of the car feels like it is bouncing very bad. I have no idea why it does this, any clues?
I have the entire Spohn suspension package, a Moser 9" posi rear, and a custom rebuit 700R4.
Old Dec 19, 2003 | 10:31 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Try checking your transmission mount.
Old Dec 20, 2003 | 01:29 AM
Bandit5's Avatar
It's brand new. I just had my transmission rebuit two weeks ago. It did it before, and it is still doing it.
Old Dec 20, 2003 | 05:33 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Could it be that the bushings on his LCAs are worn out?
Just a guess, but I am not sure if that would even cause this...
I would start by inspecting the rear end suspension (all of it) for worn bushings, bent parts, missing parts, worn parts etc.
Old Dec 20, 2003 | 08:35 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I agree. I don't think this problem has anything to do with your transmission. If it did you would most likely have the same problem in 1st gear, because low and reverse run off the same band.
Check all the bushings, u-joints, ect. Oh, and also check the trans mount just to be sure. Jack up the tailshaft of the trans and see if the mount seperates. I highly recommend swapping to the Energy Suspension poly mount if you haven't already.
Old Dec 20, 2003 | 12:10 PM
Bandit5's Avatar
I don't think it has anything to do with the tranny either. Was figuring more rear end and MAYBE the suspension.
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
greenyone
Sep 2, 2015 03:39 PM
CORV3TT3
Aug 23, 2015 11:26 AM
hokis
Aug 9, 2015 03:57 PM
