Let's lay out some data on the stick shifts...
Old Jan 1, 2004 | 05:48 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Fbody V6 T5
14 spline, 1" thick input shaft
9-1/8" clutch with a 1" hub
Ratios:
1st - 4.03
2nd - 2.37
3rd - 1.49
4th - 1.00
5th - 0.76
Fbody V8 T5
26 spline, 1-1/8" thick input shaft
10.5" (?) clutch with a 1-1/8" hub
Ratios:
1st - 2.95
2nd - 1.94
3rd - 1.34
4th - 1.00
(MK6 code)
5th - .73
(M39 code)
5th - .63
The Fbody T5 is also tilted 17º The V6 and V8 bellhousing are interchangeable, as far as bolting to the transmission (different engine bolt patterns). I've also heard that ALL Chevy T-5's have a 7.18 inch input shaft length and 0.590 inch diameter pilot bearing extension. Can anyone verify/deny this?
Old Jan 1, 2004 | 05:52 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The V6 and V8 bellhousings are most definately not interchangeable.
Eveything else seems right on the money.
Old Jan 1, 2004 | 06:00 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
That Ruins my plans. So i cant just take my 85' v6 with a t-5 and and do a TPI swap?
Old Jan 1, 2004 | 06:07 PM
You will need a V8 T5 bellhousing. Otherwise all of the V6 parts will work.
The V6 stuff isn't as strong as the V8 parts either. If it's just a cruiser then you will be fine. Most street cars won't have enough traction to break the trans or smoke the clutch, unless you really beat on it. If drag racing is something that you plan to do often you would be better off with a V8 T5, and even then you may run into trouble.
Old Jan 1, 2004 | 06:22 PM
Doward's Avatar
LOL, sorry... didn't clarify... better now?
Old Jan 2, 2004 | 09:07 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Re: Let's lay out some data on the stick shifts...
Originally posted by Doward
Fbody V8 T5
Ratios:
5th - .73
5th - .63
if your trany code is M39
MK6 had a .73
Old Jan 2, 2004 | 10:01 PM
Doward's Avatar
Re: Re: Let's lay out some data on the stick shifts...
Originally posted by novass
5th - .63
MK6 had a .73
Fixed. Any info on those input shaft lengths?
Old Jan 2, 2004 | 11:02 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Incorrect about the V6 T-5 to V8 even with a v8 bell housing. The V6 T-5 input shaft has less splines on it, Clutch for a v8. You cannot just change out the V6 input shaft for a v8, won't fit, well from what I have read on this site anyways. You will need a v8 t-5.
Old Jan 3, 2004 | 11:05 AM
If he continues to run the V6 clutch assembly on the V8 engine it will work fine. Plenty of people on this site are doing just that.
Personally I wouldn't because of strength issues, but it will bolt together and work.
Old Jan 3, 2004 | 01:07 PM
pasky's Avatar
Oh ok, I take it back then.
Old Jan 5, 2004 | 10:12 PM
Doward's Avatar
Still need input shaft lengths... or if someone just has the length for the aftermarket T56 tranny...
Old Jan 6, 2004 | 04:19 AM
Wezzeles's Avatar
Car: Camaro
can you take a v6 t5 and rebuild it with kit for v8 t5s?
Old Jan 6, 2004 | 02:36 PM
I've got a lot of T56 dimesnions, but can't find one for input shaft length. If you email Tremec they will tell you. That's where I got all my information from. They are really good about getting back to you quickly.
Falcon50
Aug 22, 2020 03:26 PM
bjpotter
Oct 4, 2015 07:48 PM
Drone358
Sep 28, 2015 04:55 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ndndndnd
Sep 28, 2015 08:00 AM
