Would someone mind doing me a favor? (Need pics)
Old Jan 1, 2004 | 09:57 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Hi. I believe that the uppermost part of my T5 gearbox is leaking. It's hard to determine if it is that, or the tail seal, but I'm leaking TONS of fluid when I drive, but I cannot pinpoint the leak exactly.
Does anyone have any photographs of the upper part of the transmission, where the shifter handle enters the gate plate? Where are the seals located, and what should I expect to find, when I pull my center console to take a look when the weather warms up next spring?
Thanks in advance for the help!
Old Jan 1, 2004 | 11:08 PM
Z_Ghost's Avatar
There is no gasket between the shifter and the trans they just use silicone.
Attached Thumbnails Would someone mind doing me a favor?  (Need pics)-top-t5.jpg
Old Jan 2, 2004 | 12:41 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
FWIW....
TTC has their manuals online in PDF format.
http://www.ttcautomotive.com/English/home/home.asp
Their manuals are excellent and have plenty of exploded diagrams, instructions, etc.
http://www.ttcautomotive.com/English...ice_Manual.pdf
HTH
-Schultzy
Old Jan 5, 2004 | 03:52 PM
Thank you both!
Old May 18, 2004 | 06:37 PM
Does this look a little wet to you???
Attached Thumbnails Would someone mind doing me a favor?  (Need pics)-bootleak.jpg
Old May 23, 2004 | 05:32 PM
Mmmmm... Much better! Hopefully this will fix my drip!
Attached Thumbnails Would someone mind doing me a favor?  (Need pics)-cleanboot.jpg
Old May 26, 2004 | 10:29 AM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
If you guys get tired of the mess and sometimes stink of silicone, try an anaerobic seler better suited for the job. http://www.holdtite.com/english/handbook/page07a.htm is an example.
Clean parts with brake parts cleaner, apply a even bead.
Not near as messy and makes a much nicer looking finished product. My $.02
:rockon:
Old May 27, 2004 | 08:52 PM
Yeah, I originally installed the plate upside-down, because I was paying attention to the patent pending text on the plate, and not to the plate itself, so I got RTV all over my socket when I flipped it back around. If you could see it, I would have taken the time to clean it all up, but since chances are good that I'll never have to go there again, I wont waste what little time I have on fixing the car. I still have a few more small things to fix up and then I'll be back to 110%
Old Jun 4, 2004 | 08:01 PM
Well, at this rate of assembly, I should be done by 2007... No screws left over yet!
Attached Thumbnails Would someone mind doing me a favor?  (Need pics)-bootin.jpg
scotrans am
European Region
May 30, 2018 03:48 PM
R13_Braz
Sep 18, 2015 05:00 PM
2MNYMaros
Sep 15, 2015 11:36 PM
Deemax
Sep 12, 2015 06:53 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
