Compression Fitting?
Old Jan 2, 2004 | 03:04 AM
IrocZed's Avatar
On Probation
Car: 03 BMW Zed4, 87 Camaro IrocZed 305 TPI
Engine: 2.5 I6, 305 TPI V8
Transmission: 5 spd., T700R4
Hi,
I just finished changing the flexplate but bent the rad. feed line from the tranny when pushing the tranny back. It fell short about 3"es so i cut it and bridged the gap with some transmission hose and clamped the ends. Took it for a test drive and it started leaking.
I got home took the hose off, flared the ends of the line and reattached the hose clamped the ends again, tighter now. This time the line burst. Possibly one of the flares cut in to the hose or something.
Anyhow i decided to go the compression fitting route. I got 2 5/16" fittings and a 5/16" brake line from Autozone.
As the brake line is a little 'fat' to go into the c-fitting, i sanded it to fit the c-fitting. I have everything fit tight and snug. But i do notice both the 5/16" brake line (which i sanded to fit the fitting )as well as the original tranny lines are kind of squished when they go into the c-fitting.
Did I overthighten the c-fitting compression nut. Will the brake line (about an inch long) withstand the tranny fuid temp and pressure (alongwith the fact that i thinned the outer surface of the line or will it burst like the tranny hose over time.
Happy New Year to All
Thanks Sean
Old Jan 2, 2004 | 06:17 AM
ede's Avatar
ede
asking on one board is enough to get an answer. it doesn't matter if you thought asking on more than one would increse the odd or you'd get more knowledgeable people that might not read all the boards, one board is enough.
Old Jan 2, 2004 | 12:58 PM
IrocZed's Avatar
On Probation
Thanks for your concern. However my initial starting problem was answered when I posted it multiple times in seperate boards.
In other words it does increase the chances of getting a knowledgeable answer. It might happen that one is browsing one board and not the other.
Anyhow anyone have any answer to the query.
Thanks for your time.
Old Jan 2, 2004 | 01:00 PM
IrocZed's Avatar
On Probation
Hi ede,
I saw your reply. Thanks for that.
Regards Sean
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
