Had to pull engine with converter attached...
Old Jan 2, 2004 | 04:40 PM
dennis6's Avatar
Car: 1991 Camaro RS
I pulled the 305 that was seized from my 91 RS. I had to pull the converter attached to the engine, where should I look for possible damage to the tranny?
Thanks.
Old Jan 2, 2004 | 05:13 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
It shouldn't have hurt the trans. I've done it before, and nothing was wrong with the trans. I even yanked the input shaft out of a C6 once by accident. Put it back in and it was fine.
Old Jan 3, 2004 | 07:15 AM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks, I was told it might damage the front pump.
Old Jan 3, 2004 | 12:51 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Replace the torque converter seal before you put the new engine in.........
Old Jan 3, 2004 | 08:56 PM
Yeah, you should always do that. Even if nothing was out of the ordinary when you pulled the motor. It's cheap insurance against a leak.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
