Droppin clutch on an auto
Old Jan 4, 2004 | 06:37 PM
Rotek's Avatar
Car: '89 Firebird Formula
Engine: 350 w/ carb
Transmission: A4
I havn't done this nor do I plan too.. BUt I was just wondering if you could shift your car into neutral stock R4 and rev your engine then put it into drive.. would this simulate dropping your clutch like in a manual or owuld it just end up messing your tranny up.. just a question..
Old Jan 4, 2004 | 06:41 PM
likeistoleit's Avatar
Car: 87 Iroc
Transmission: Tremec Tko
Dont do it, unless you want to become really familiar with your tranny guy and part with some hard earned cash.
Old Jan 4, 2004 | 06:43 PM
Rotek's Avatar
Engine: 350 w/ carb
Transmission: A4
lol alright 10-4 there good buddy... Thought it might just thrash it..
Guess you'd drop alot mroe if you did do it eh? eheh
Old Jan 4, 2004 | 08:03 PM
WS6Formula305's Avatar
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
I saw a video somewhere a while ago where a guy did a neutral bomb in a 350 Z28... driveshaft shot out from behind the car
Old Jan 4, 2004 | 11:25 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Never a good idea. A very easy way to blow the converter, or toss a driveshaft as mentioned.
What you want is a trans brake. Check out the thread.
Old Jan 4, 2004 | 11:39 PM
MdFormula350's Avatar
ouchy, definitely not good to do.
Old Jan 5, 2004 | 01:37 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
The logistics would be appreciated if somone could explain (cough probuilt or tko cough) what exactly happens inside the transmission when someone "neutral bombs".
Old Jan 5, 2004 | 04:25 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Stuff breaks.
Old Jan 5, 2004 | 04:56 PM
My understanding is that the pump is spinning at a high rpm and building a good deal of pressure in neutral. When you slam it into gear all that force is directed directly through the converter, and it balloons the converter case, sometimes permenantly. This can tweak the fins inside out of alignment, as well as ruining the clearances inside the converter, quickly leading to it becoming junk,
Even if the converter holds and the trans engages it puts a horrible shock load on the driveshaft, which can lead to it making its exit stage left.
Old Jan 5, 2004 | 10:27 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Thanks. It's good to know why something is wrong instead of just knowing it to be wrong.
Old Jan 6, 2004 | 09:29 AM
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
88rscamar0
Sep 23, 2015 09:08 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
