help please.
Old Jan 5, 2004 | 07:00 PM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
help please.
my car started to make an rpm-related noise wich i think could be related to the u-joints but im not sure. it sounds like little bells under my car,i performed a search but w/o luck,so any help is welcome.thanks
p.s.it goes off when im at a stop but as soon as i accelerate it starts to make the noise
Old Jan 5, 2004 | 10:52 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Put the trans in park and lock the wheels with the parking brake. Try to rotate the driveshaft by hand, and pay particular attention to where the front and rear yokes go into the trans and attach to the rear. If there is slop in the u-joints you've found your problem.
How many miles on the car?
Old Jan 8, 2004 | 12:30 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
if it is the manual tranny car it may be a throwout bearing. They tend to jingle when they are going bad.
Old Jan 10, 2004 | 06:24 PM
sr.bond's Avatar
good point.!
thanks guys,the car is the stick shift one,it could be the bearing.im actually fed up with her since she's giving me weird problems,she broke a stupid bracket that holds the shifter in place to the tranny then after getting that thing welded again and installing it in place the shifter wont let go reverse gear unless i force him to first wich leads me to this question,can i install a t5 tranny with my current mechanical clutch linkage?
Old Jan 10, 2004 | 09:46 PM
I do not believe so, but converting to hydraulic is simple. All you need is the sealed master/slave assembly from a 3rd gen car.
Gunner242
Dec 25, 2015 04:49 PM
jaridjohn
Oct 5, 2015 07:01 AM
Jonesyfxr
Sep 26, 2015 02:08 AM
cougar20th
Aug 27, 2015 08:04 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
