tranny lock-up?
Old 01-07-2004, 12:42 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
tranny lock-up?
I bought one of those vacuum lock-up kits from summit... worked well, till i riped apart my engine and broke the vacuum switch. I was thinkin... that vacuum switch must send power to the lock-up seleniod when the engine is pulling vacuum or running right? So can't I just put that switch on keyed power and do the same thing? I was going to run it to my ECM and be done with it... except my ECM and harness was out of a manual camaro. So where the wire should be... there aint one comeing out of the ECM... just key it?... or switch it? or what ever... constant power (well when the car is on) to the seleniod wont hurt it will it?
Old 01-08-2004, 01:57 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
From what I understand the vacuum switch actually disengauges (turns off) the lockup when there is a drop in vacuum, such as WOT, or of course when the engine is off. This keeps the TC Lockup from lugging the engine when you put the pedal down.
I have just recently done some work to wire up my originally-manual-equiped car, I basically provided power to the hot side of the solenoid (through a break cancel switch) and a ground (through the 4th gear pressure switch) so my TC Locks up whenever I'm in 4th, which is not so great, so I am now looking into a vacuum switch myself. When I hit 4th, the TC Locks up, and if I give it fairly light throttle (not enough to get it to kick down to 3rd) my engine lugs.
Old 01-08-2004, 04:21 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
The switch sends the signal to unlock/lock the converter at a certain vacuum point, I don't think you can wire up anything that will take it's place and still be automatic. It's a TCI kit I think, or at least mine ordered from Summit was, I'm sure you can buy the switch itself for pretty cheap from them.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
bjpotter
10-04-2015 07:48 PM
Nick McCardle
09-10-2015 08:36 PM
IROCZ1989
09-04-2015 11:54 AM
Quick Reply: tranny lock-up?
