T-56 came in today, couple of ?'s
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Ok, right now its at a shipping company I just went to go check it out and everything looks real good engine and tranny.
However, im playing with the shifter and I can't seem to find reverse, is there a reverse lock out switch on the T-56's because the car has the clutch and all hooked up I could put it in 1-6 but could not find reverse.
I would disconnect it however, I am waiting for a friend to get off work to use his truck and take it to my garage. Is this normal?
Btw, man I love the way the shifter feels, it has some sort of aftermarket shift **** on it, but man its just so stiff, it stays in gear so easily, feels pretty beefy, can't wait to do some downshifting with it. :rockon: :rockon: :rockon:
Engine: Many
Transmission: Quite a few
sometimes its tough to get a manual trans in and out of every gear if the engine is not spinning. The synchro's (or gears) don't exactly line up, if you wiggle the shifter in and out, sometimes you can get it to go into every gear. This is especially true in reverse, as alot of transmissions aren't syncrhonized in reverse(like a muncie or t-5 or t-10). I'm not sure about the T56 though, it may have a lockout also, you might have to pull up on the ****, or push down on the **** to get it in gear.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: T-56 came in today, couple of ?'s
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if the car was running, id say put it in a diff gear, then into reverse....
since its out, have someone turn the input shaft back and forth as you put it into reverse. and yea, its a lil stiff to get it over that far too...... you have to push thru the lockout.
Car: 86' Z28
Engine: 355
it has a reverse lockout solenoid on the right side. push really hard and you'll be able to push through the solenoid and into reverse. All should be well.
Eric
Eric
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You're probably coming up against the reverse lockout solenoid. You really have to slam it sideways to get into the reverse gate. It's especially difficult when the trans isn't mounted in the car and you're just doing it on the bench or floor.
I always go from 1st to reverse in my T56. Most transmissions seem to be like this. The T5 wants 5th and then reverse. My WRX wants the 1-reverse pattern. It has to do with the lack of reverse synchronizers as mentioned.
Yea, I always went from 5th to reverse in the T-5, inever tried 1st to reverse on the t-56. Im not worried as long as its normal, I have no need to ram it in there, I don't want to harm anything. Thanks again.
Oh I also wanted to ask, what is skip shift? My t-56 is out of a 95 trans am so im sure it had skip shift. Is skip shift built directly into the T-56 or the PCM? If so its coming out, I don't need no computer doing work for me, hell thats why I drive a standard.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I has to do with the PCM. Just don't connect the solenoid.
The skip shift, or CAGS (computer aided gear selection), is a solenoid on the side of the trans. It's on the side of the four bolt top cover plate. Without the computer controlling it it won't work. A M22 drain plug with a flat rubber gasket plugs the hole perfectly if you want to remove the solenoid.
Car: `86 SS / `87 SS
TKOperf: thx for the tip on a CAGS solenoid plug.
Yeah, I just took the solenoid to NAPA and matched up a plug. I didn't want something hanging off my trans that didn't do anything. I deleted the CAGS arm inside the trans too, but that's a lot of work if you aren't already rebuilding the trans. I wanted all of it gone. I consider it an abomination.
Old habits die hard with the 1-reverse shift. I did just put it in reverse a couple of times and it didn't grind.
There are companies out there that are offering several different shifter mounting locations for the T56. One is where the factory 4-bolt cover goes, as with the Cobra you saw (they have a big problem with shifter placement because the engine is set back so far). I know the Viper tailshaft housing mounts the shifter father forward, so that's another option. The T56 has been used in so many applications that it's totally possible to get different locations just with the factory stuff.
Car: 1994 firebird
Engine: 427ci lsx bowtie block
Transmission: tremec t56 micro edged gears
Axle/Gears: Strange dana 60 with racing spool
t-56 couple of questions
ok guys i have a t-56 out of a 93 and i am trying to put it in my 87 gta. i need to know if the braket from the old t5 for the torque arm can be used for the new t-56??? i dont have one that came with my t-56 so where could i get one if the t-5 one wont work??
No, you need a 4th gen torque arm bracket. I'm sure you can get it from GM, or a salvage yard if there's one around you that has cars like that (we don't around here, they all go to high perf salvage places).
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You know what? You could very well be right. I swapped from a 700R4 to a T56. I looked over the torque arm mount toroughly and took a couple of measurements before I determined it wouldn't work, so I used the one on the T56.
T5s may be different, but I figured they weren't. Shouldn't have assumed that.
Car: 93 240SX
Engine: LQ9
Car: 1994 firebird
t-56 came in couple of ??s
hey thanx for the info. i already swapped my 700r4 to a t-5 and so i have the torque arm bracket for the t-5. i remeber that the mount that bolts into the bracket (basically the part that wraps around the torque arm to hold it to the bracket that bolts intot he tranny) was taller than my auto one. it seams the torque arm i have is different than the one this t-5 tranny came out of. how can i fix that problem?? can i get a different bushing?? or what do i need to make it so my original torque arm will fit into my torque arm mount and bracket that i have for my t-5 that i will use for my t-56. i figure while i have it on a lift and have free autoshop time i might as well fix everything i can.
tonys91rs
Oct 10, 2015 03:31 PM
Numbah-1
Sep 12, 2015 08:57 PM
