do they make a bolt in replacement for t-5
Old Jan 17, 2004 | 02:35 AM
chad89ta's Avatar
do they make a bolt in replacement for the t-5 that can handle 400 hp
Old Jan 17, 2004 | 07:02 AM
ede's Avatar
ede
wct5, t56, th350, th400, th700r4, th200, PG
Old Jan 17, 2004 | 11:17 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
T56 gets my vote. Probably the easiest manual swap, and easily the strognest (450+ lbs/ft.).
Old Jan 18, 2004 | 01:48 AM
chad89ta's Avatar
well my t-5 is shot, i want to stay with manuel trans,but i had a costom crossmember made for my t-5 so i could run true duels,the crossmembers bolts up just like the factory 1 but give me good ground clearance, so i need a tranny that can handle power,and bolt up to the crossmember
Old Jan 18, 2004 | 02:01 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Actually, the Tremec TKO is the easiest swap, everything bolts up with xmember and everything.
Old Jan 18, 2004 | 02:20 AM
chad89ta's Avatar
where do you get the tko,is there a website for those
Old Jan 18, 2004 | 11:52 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Trans
Check here:
http://www.g-forcetransmissions.com/
Old Jan 18, 2004 | 09:52 PM
5 gears instead of 6...
Old Jan 21, 2004 | 09:12 PM
mikeu90rs's Avatar
Car: 90 RS
Engine: 355 ci L98
Transmission: G-force T5
Have you looked into G-force?
I have a G-force T5 in my car and, so far, it has handled well over 400hp on slicks. Installing it was exactly the same as bolting in another wct5... Just one of your options.
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Fronzizzle
Aug 9, 2015 01:15 PM
