Will a 95 caprice rearend fit my 92 rs?
Old Jan 20, 2004 | 05:30 PM
dillardracer's Avatar
Car: 1992 rs camaro
I am trying to find out if a rearend out of a 95 caprice cop would fit in my 92 rs. My camaro has drum brakes and the regular crappy 10 bolt. The caprice rearend is called a 9C1, with posi, disc brakes, and 3.08 gears. It has 30 splines. I know the brake proportioning would be different, but I'd like to find out if everything else will bolt up. Any advice would be appreciated.
Old Jan 21, 2004 | 12:28 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
No it won't. The mounting points are different for the lower arms; there is no provision to mount the torque arm, and the width is likely not even close.
Pete
Old Jan 21, 2004 | 05:58 AM
ede's Avatar
ede
any 3rd or 4th gen f body rear would be a direct fit, no other rear will bolt in and work
Old Jan 21, 2004 | 10:06 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Stock 3rd and 4th gen 10-bolts, Borg/Warner 9-bolts, and special Dana 44s will all bolt in.
4th gen rears are wider, so your tires will stick out past the wheel arches. This looks pretty bad, and is illegal in most states for a street car.
Aftermarket bolt in 9"s and 12-bolts are common. A fair number of people are also starting to modify 8.8" Mustang rears to work in the F-body, but I haven't seen a bolt in unit yet.
86Firebird86
Dec 26, 2015 07:21 AM
New2Chevy
Sep 28, 2015 12:35 AM
Strick1
Sep 6, 2015 10:38 AM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
