why do they say?
Car: 1992 Firebird Formula WS6
Engine: LB9 305 TPI
Transmission: TH700R4
why do they say?
Why does everyone say that a 700R4 loses 20% power? Every racer I have talked to, numbers I've checked out online, and a friends dyno run would suggest otherwise. I have seen no proof as to why this is said. I have also read that that 20% number is just an average number assigned to automatic transmissions in general, NOT all. I would just like some proof to the statement.
If that were the case, I have a hard time believing that any automatic tranny would make it into production because of fuel mileage.
Between an auto and manual firebird formual 305 TPI, the auto (at the crank) made 210 horsees (th700r4) and the manaul makes 230 horses at the crank. Now YES this is at the crank, but I have seen MANY Dyno Tests results, some of which posted in various places at this site and others that have PROVED that the autos lost roughly between 5-10%.
This would suggest that the loss is not just because of the transmission and may be because of the rear, etc. I just don't think the transmission is the only reason.
Let the flame (or
flag) come up. I know its inevitable, but I want some proof!
thanks!
Let the flame (or
flag) come up. I know its inevitable, but I want some proof!thanks!
Re: why do they say?
Let the flame (or
thanks!
Let the flame (or
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I think the reason being is because the 4L60E out of the fourth gens are rated at 18-22% drivetrain loss with an automatic and 16-18% using the T-56 manual. Count this with the aluminum driveshaft as well. Isn't the 4L60E the 700r4 with beefier internals? Hope that helps.
Engine: LB9 305 TPI
thats insane to think those numbers could be correct on just a transmission though, or even through a drivetrain (especially if the whole thing is built) that would mean a 1000 hp car, is only putting down 750 to the ground....I find that very hard to believe.
Also that would mean that a 92 Z28 would lose horribly to a stock first gen DSM. Which they don't. So there is something up with those numbers.
Oh yah, if the whole drivetrain is true, why is is that the 2002 camaro SS (and firebird equivalent) can do a quarter mile VERY quickly for a stock car and only have 325 horses? theres no way with 20% drivetrain loss theyd be able to make it down that track as quick as they do, with the amount of weight those cars have.
cheers
cheers
the amount of power to spin the trans and entire drive line is going to be fixed, say XX amount of HP not a variable like XX% of the HP produced. the way you're appling it the amout of lose goes up as HP goes up.
Car: 1990 Iroc-Z
Right. Ede nailed it.
Think of it as a percentage of you cars particular power output.
So...
If a stock thirdgen L98 gets engine dynoed at 245 horsepower, and then loses 20 or 30 horsepower because thats what it takes to "spin" the drivetrain then it is in effect losing 8 - 12 percent of its power.
If a modded thirdgen L98 gets engine dynoed at 300 horsepower, and then loses 20 or 30 horsepower because thats what it takes to "spin" the drivetrain then it is in effect losing 7 - 10 percent of its power.
In actuality, the more power your combo is making, the LESS it loses to "spinning" the drivetrain.
So...
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
cheers
cheers
Car: '82 Z28
Engine: 350HO
Transmission: M4
Originally posted by ShiftyCapone
#2 they have very flat power curves.
LS1s run 13's stock in the quarter because they put down about 290-300rwhp on a chassis dyno. and for the weight of the car, that much of horsepower should get you low 13 second quarter mile.
Car: '90 RS
Engine: 377 LSX
Originally posted by scottland
LT1's have a flat torque curve, but LS1's don't.
Car: '90 RS
Engine: 377 LSX
Originally posted by 25THRSS
my LS1 makes well over 300 tq from less than 2k rpm all the way to more than 6k.
Engine: LB9 305 TPI
Ok, I understand that the drivetrain uses said amount of power to turn and that power is then lost when measuring from the wheels...but 20%?? I'm sorry, unless I see numbers proving that I just can't believe that such a high percent of our power is lost.
For instance, My brother has a 1st Gen DSM, Turbo, AWD DOHC (manual)...all that. My car is a 305 92 Formula (th700r4). My car isn't stock but it was when I got it and I could probably take him, maybe not all the time but I could.. not by all that much, but I could and now that I did a full header back system I would smoke him!..and he drives pretty good. Now take our stock numbers, 210 HP with 215 lbs of torque or so (and that is fact, we just got the new engine), and mine 210 stock with 285 lbs of torque. Now I know torque makes up for a lot BUT if your numbers are correct THEN His car losing 10 percent as a manual would yeild 189 HP, and mine at 210 Stock with my auto would yeild 168 HP with the 20 percent loss. Now, even with torque, I would not be able to beat him, also because he's AWD. So I just can't believe those numbers...because I could BEAT him. I couldn't do that if these numbers were correct. And assuming those are correct and his car weighs 500 lbs lighter...he would SMOKE me, but he can't! so
cheers
cheers
Engine: LB9 305 TPI
Yes, 60 torque does make up for 20hp less BUT does it make up for 20 less HP, 500lbs and him in an AWD?? I think not
Car: 2002 Z28
you are not going to get the answer you are looking for by arguing with people on the boards, either go look for some stock dyno numbers or get your car dynoed and do the math.
Also, dont those all wheel drive cars loss a **** load of power through the drivetrain, i think that 10% claim is alittle on the light side for the the DSM.
Engine: LB9 305 TPI
Arguing
Lol You call that arguing?? Hmm, ok. Anyway.....I was just stating my thoughts, and numbers I've gathered...so I am doing the math. But good point on the AWD loss, I'm going to do some more checking on that too see what their loss is.
Lol You call that arguing?? Hmm, ok. Anyway.....I was just stating my thoughts, and numbers I've gathered...so I am doing the math. But good point on the AWD loss, I'm going to do some more checking on that too see what their loss is. Joined: Feb 2001
Car: '90 RS
Engine: 377 LSX
Arguing
Arguing
Lol You call that arguing?? Hmm, ok. Anyway.....I was just stating my thoughts, and numbers I've gathered...so I am doing the math. But good point on the AWD loss, I'm going to do some more checking on that too see what their loss is. On a side note, they claim that newer cars have a driveline efficiency of 90% but I am skeptical a bit. That is what they tell us here at school for any driveline calculations.
Also if your torque converter is not locked than the power losses increase as rpm does. In a viscous situation the faster go the more friction there is. That is how shocks work. This is not true for dry friction where you just have to overcome the weight of whatever it is you are moving.
Engine: LB9 305 TPI
Awesome. Thanks Shifty Capone, lots of good info there, and it makes sence...AND you stated reasons why
That's what I'm looking for. Ya, I knew about the power curve, but I just didn't think it would benefit me all that much vs him if we had the same power going through (even though I have more torque) with him in an AWD and with a lot less weight. I knew I would pull on him at higher speeds due to his loss, but I figured that wouldn't matter as much in a 1/4 time since he would have a greater amount of traction. So all in all, that makes sence, and I would tend to agree more with the 90% efficiency on new trannies..I wouldn't think the 700R4s would be THAT much worse. Anyway, thanks
Cheers
Cheers
Engine: LB9 305 TPI
I've always heard that the 4WD cars had alot of rolling resistance, which I guess is why they lose more in higher speeds. I guess thats why they've created four wheel drive systems that transfer torque and poewr only to the back wheels when your already movin. Pretty innovative stuff. And I also still think that 20% is too high of a number for how fast the newer SS and WS6 can move. Even with 360 Horses (advertised 320). *** I hope they brind one of those cars back.....But I digress..
BTW rode in a WRX (not STi) that lil car can move! I was impressed.
cheers ya'll
cheers ya'll
Car: '90 RS
Engine: 377 LSX
cheers ya'll
cheers ya'll
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Well think of it this way. GM rates the LS1 at 350hp for the vette. This is the same motor that is in the f-bodies but it was a lower rating because GM can't advertise it to have the same as their bread and butter.
Car: '90 RS
Engine: 377 LSX
Originally posted by GTA-SPD
If I'm not mistaken, the F-Body LS1 has iron heads and the Vette has alum heads, and a different cam.
Engine: LB9 305 TPI
Hey Pat. The First Gen DSM's are in my opinion some of the fastest stock imports (or to be precise, DOMESTIC Imports, since they were built in american factories, in Normal, Illinois) to roll out of production for their time. They were the Mitsubishi Eclipse, Chrysler Laser, and the Eagle Talons..the talons were the faster of the two as far as I know. The Talons could come with a 14b Turbo DOHC 16 valve AWD Package...rated between 195 hp. They also had slightly more torque than HP (roughly 205lbs)which was kind of odd for an import. Either way, they are faster than the Second Gen Eclipses and talons....which used a smaller turbo running at max boost, whereas the 1st gen wasn't at max boost. My brother has the Eagle Talon model stated above...fastest of the bunch. I may not have included all the info here...but I'm tired and I put as much as I can think of. Night
P.S. when I call them "fastest" I"m not including the OUTRAGIOUSLY overpriced Imports such as NSX's and skylines...or any of the newer cars (i.e. EVO)
cheers
cheers
No problem there Raven. I just could'nt figure out what cars you were referring to using the term "DSM". Yeah I'd have to agree some of them are pretty damn quick. I had an eclipse gsx turbo and a nissan 300zx twin turbo both give me a really decent run for my money in my 69 Camaro. If I would've been in my 89, there would've been no contest, they would've blown my doors off in that car!
whoo hoo nice convo about the power loss. I think I will be agreeing with ede on this one. how would adding more power make the amount of power your drivetrain suck up go even higher? that really doesn't make any sense at all if you think about it.
Why is it that subaru and mitsubishi are holding on to the all time four wheel drive thing? I understand their evo and STi are both based off of rally cars, but why not make it so you can shut off all wheel and just run on front or all wheel, or back and all wheel.
cheers, nice convo, this is interesting
BTW thats plymouth laser, not chrysler ravenshorn
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
my 2bits
I'm no genius.. but from what I understand... there will be HP measured at the flywheel vs. the HP to the wheels. The HP to the wheels will be a smaller # due to energy used to operate the entire driveline (there IS resistance all along the driveline). Please correct me if I'm wrong.
oh your very correct, it does lose poewr, the debate here, is some say you lose 20% indefinately regardless of how much power your engine makes or how your tranny is built, and others (like myself,ede, and ravenshorn) who think that there is a set number your drivetrain takes up, and doesn't scale as your power scales.
cheers!
cheers!
Engine: LB9 305 TPI
Wow, did I call it a chrysler? haha Sorry bout that. Anyway, I was reading through the posts again, and I would have to say that Ede and D Stroy both nailed it. I didn't quite catch what they said earlier but it makes complete sence. X-wolf and I were discussing how it didn't sound right at all that the same vehicle with 400 hp would use so much more hp to spin the same drivetrain than if it had only 240 hp. It didn't make sence. SO thanks Ede :
Car: '90 RS
Engine: 377 LSX
cheers!
cheers!
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Now take our stock numbers, 210 HP with 215 lbs of torque or so (and that is fact, we just got the new engine), and mine 210 stock with 285 lbs of torque. Now I know torque makes up for a lot BUT if your numbers are correct THEN His car losing 10 percent as a manual would yeild 189 HP, and mine at 210 Stock with my auto would yeild 168 HP with the 20 percent loss. Now, even with torque, I would not be able to beat him, also because he's AWD. So I just can't believe those numbers...because I could BEAT him. I couldn't do that if these numbers were correct. And assuming those are correct and his car weighs 500 lbs lighter...he would SMOKE me, but he can't! so cheers
Ok, I have been told otherwise, i thought gm rated all thier vehicles at the wheels also but I was told its at the flywheel over at camaroz28. I don't know what to believe now =/.
Car: 1995 Corvette
Its at the wheels now for sure... When the exact change took place I'm not 100% sure of... But it was back in the 70's for GM...
Ummm... Your Formula has 210 (or 205 but whatever) NET hp... Everything past some year in the early seventies is rated as net hp... that means at the wheels already... driveline accounted for...
cheers
Their ratings are 100%, absolutely at the flywheel. Before, engines were rated with no accessory drag, etc. Now they are rated exactly as they are put in the vehicle.
Take the lt1 for example, gm rates its camaro z28 /w lt1 engine at 275 hp
Is that flywheel or rear wheel?
Car: '90 RS
Engine: 377 LSX
GM and just about every car manufacturer rates their engines at the FLYWHEEL.
Car: '90 RS
Engine: 377 LSX
Although, keep in mind, not all the specs they put out are always accurate. GM for 1 likes to underrate most of their engines big time.
When we all know that everyone dumps the two rear seats and it takes more than 300hp to run high 12's.
