anyone done a 12 bolt swap?
Old Jan 24, 2004 | 03:25 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
ive checked on the complete 12 bolt rearend from Moser, and it sounds like a winner. has anyone done this swap? any major problems? costs?
Old Jan 24, 2004 | 06:05 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Re: anyone done a 12 bolt swap?
if you dont already have disc brakes you will need to get them in order to use that rear....
i have a moser 12 bolt with richmond gears, an eaton posi, ford housing ends, the aluminum support cover, and 33 spline axles.....its awesome.....
all together including all the brake parts, it cost me about 2500 bucks.
Old Jan 24, 2004 | 06:35 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Re: Re: anyone done a 12 bolt swap?
I have the same with 3.08 gears and no problems
Steve
Old Jan 25, 2004 | 07:27 PM
Engine: 355
i talked to moser, and they said i could keep drum brakes, but would have to find them from a 81 or older camaro. this would be the route i would go with for the cost factor.
Old Jan 25, 2004 | 10:54 PM
Car: '91 Camaro RS
they told me youd have to use pre 79 ford torino drum brakes......i got all the brake equipment for a disc brake setup off a 9 bolt rear at a junkyard for 100 bucks
if i was you, id order the rear with ford housing ends and do the same thing.....cause you wont need c clip eliminators, as your axles will be bolt in....and you'll have alot bigger axle bearings too
Old Jan 26, 2004 | 06:07 PM
Engine: 355
they told me that the 7.5 inch rear brakes wouldnt work. ill get in touch with them again and get it all straightened out. thanks for the help man
1984HO
Mar 19, 2021 11:59 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
theurge
Aug 21, 2015 12:46 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
