Mystery Trans Leak???
Old Jan 26, 2004 | 05:43 PM
Strokeme's Avatar
Well, I've got my car in storage for the winter, but still like to go check on it every once and a while, just to make sure everything is ok with it. Well the other day, I wander into the garage, only to find a large puddle of trans fluid under the car. The car hasnt been driven in months, hasnt moved, been pushed, rolled, nothing. All I can think is that the front seal maybe went out? It looks alot like the fluid came from the front of the trans, as a couple of droplets are hanging on the transpan. The pan itself is solid, the cooler lines look good, the driveshaft is still there.
Is it possible for the front seal to just...go out? I live in Northern Illinois, so it has been exposed to very cold temperatures. What do you guys think?
Old Jan 27, 2004 | 01:47 PM
Strokeme's Avatar
Maybe more info would help?
It's an 87 GTA, carb'd 350 with a 7004r, and a midwest converter.
Old Jan 27, 2004 | 03:36 PM
ede's Avatar
ede
if it's leaking from while it's not been running i'd bet on the pan or fill tube seal leaking. it doesn't take a lot of ATF to look like a lot.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
wayshegoes
Aug 17, 2015 12:00 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
