tranny swap q's
Old Jan 27, 2004 | 10:50 AM
jrm's Avatar
jrm
tranny swap q's
How hard is it to swap out the 200c from my 82 Z28, and install a hydraulic T-5? Besides the swaping of bolt-on's, (pedals, tranny, bellhousing, etc.) what cutting, welding or modifying will I have to do to make it a very clean, stock-looking setup? Also what years of third gen's would be the best donor cars?
Old Jan 27, 2004 | 12:46 PM
ede's Avatar
ede
i think all you'd need to do is drill a hole to the slave cylinder
Old Jan 28, 2004 | 09:13 AM
jrm's Avatar
jrm
thats what I thought, but just checkin
Old Jan 28, 2004 | 11:23 PM
Slick86's Avatar
Car: Pontica F-bird
Engine: 355
Transmission: 700-R4
you have got to cut a hole in the floor for the ****er
Old Jan 29, 2004 | 11:53 AM
jrm's Avatar
jrm
I guy who is putting a TH350 in his 85 camaro want's to by my stock drive shaft because he says it is longer than the 84+ F-body ones and will work with the TH350. He told me that If I am putting the T-5 in my car i'll need a shorter driveshaft. It sounds right, but I hope this guy is'nt just telling me that so he can get my driveshaft. I have an opportunity to get the drive shaft along with the T-5 I am getting out of my friend's 88 iroc, but will I need this driveshaft too? or can I still use my stock one with the T-5?
Only reason is that my drive shaft is like brand new, and the one in the iroc is all rusty and pitted.
Old Jan 30, 2004 | 01:05 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Yes you'll need the driveshaft from a 700-R4 or T-5 car, Not sure about this but you also might need the torque arm, Dont quote me on that, Im not sure. I have a T-350 in my car right now in place of a 200c, I am planning on swapping to a T-5, T-56 or 700-R4 sometime in the next year since I have to drive back and forth to PA for school!
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
