auto tranny offered
Old Jan 30, 2004 | 12:42 PM
Ghigman3's Avatar
Car: '87 IROC-Z
Engine: Modded 305 TPI
auto tranny offered
Was there a difference in the auto tranny that was bolted up to the 305s and 350s or were they the same (internally)? And Would the internals be different for different rear gear ratios?
Thanks,
Mark
Old Jan 30, 2004 | 04:14 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
As far as I know there the same, why not go to the Transmissions and Drivetrain board? they would know.
the only difference that I am aware of is in late 1986 they modified the valve-body and made some things a little better.
John
Old Jan 31, 2004 | 02:05 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Moved.
Old Feb 5, 2004 | 08:44 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
In 1987 they changed the 700R4 in a few ways. I don't pretend to understand the real differences but apparently from everything I have read the 1987 and newer transmissions were better than pre-87 transmissions. But everything between the 305 and 350s should be the same.
Old Feb 5, 2004 | 10:07 AM
Ghigman3's Avatar
Car: '87 IROC-Z
Ok, thanks. That's all I needed to know.
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
