700r4 removal question?
Old Jan 31, 2004 | 11:22 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
Can anyone tell me how they got to the two bolts all the way on top of the the engine block and how far can you jack the transmiision down because I dont want to break the screws mounted to the motor. A fast response would be grealty appreciated. thanks
Old Jan 31, 2004 | 11:57 PM
llvll4l2c91350's Avatar
disconnect everything and drop the trany as far down as it'll go with a jack underneath. it wont seem like much but should be enough to get to the 2 bolts with several extensions or one really long one and a swivel socket.
Old Feb 1, 2004 | 07:20 AM
ede's Avatar
ede
long extensions, like 3', and a socket, swivel socket works better.
Old Feb 1, 2004 | 08:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Stand next to the car, and reach down from above with a short box-end wrench. About 25 times easier than getting to them from underneath.
Old Feb 1, 2004 | 08:35 AM
camaro_60181's Avatar
Car: 1986 Iroc z28
Much easier!!!! Make sure you jack the trans up all the way so you can get your hands in there.
Old Feb 1, 2004 | 11:26 AM
Ant's Avatar
Ant
I was reading about the removal and it says to drop the exaust but i dont see why i have to drop the exaust because its not oin the way I have dual cats if that helps.
Old Feb 1, 2004 | 12:04 PM
ede's Avatar
ede
if the exhaust isn't i nthe way don't worry about it. only time i ever wanted to reach in from the top to remove transmission bolts i couldn't. always got them from below. i have an extension with a 9/16 swivel socket built into it and a 36" extension with a 3/8 male and 1/2 female ewither one or both of them work for nearly every trans i ever wante to remove.
Old Feb 1, 2004 | 01:05 PM
Ant's Avatar
Ant
thanks alot i have finally gotten the transmission out and now it's time to take it to sequoia and rebiuld it in my transmission class.
Old Feb 1, 2004 | 01:14 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i would put a transgo shift kit in,upgrade 3-4 clutch pack with aftermarket 8 or 9 clutchpack kit red alto and upgrade second gear band to a 4l60-e hi-energy one,or go to pro-built.net.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
